Marlin PID Autotune causes serial failure
I'm running Octoprint 1.3.12 on OctoPi Version 0.16.0, running on Raspberry Pi 3 Model B Rev 1.2. It is connected to an Ender 5 with a SKR mini E3 control board running 2.0.x Marlin. This combination works well for printing...I've been using it for a couple of weeks, including several multi-hour prints. I can print through Octoprint directly as well as from Cura to Octoprint. I do not see this sort of serial error when printing.
Today I tried to do a PID autotune of the hotend. When I ran the command in the terminal, I got a serial error. This behavior repeats every time I do the autotune. Adding M303 to the long running command list did not help.
Any ideas? Thanks!
2019-12-07 15:30:50,841 - Send: M303 S200 C5
2019-12-07 15:30:50,852 - Recv: PID Autotune start
2019-12-07 15:30:50,864 - Recv:  T:20.62 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:30:52,863 - Recv:  T:20.62 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:30:54,863 - Recv:  T:20.62 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:30:56,863 - Recv:  T:20.62 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:30:58,862 - Recv:  T:26.42 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:00,863 - Recv:  T:32.92 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:02,862 - Recv:  T:34.97 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:04,863 - Recv:  T:38.33 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:06,863 - Recv:  T:43.73 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:08,863 - Recv:  T:51.82 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:10,864 - Recv:  T:53.41 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:12,864 - Recv:  T:59.26 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:14,874 - Recv:  T:64.81 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:16,874 - Recv:  T:68.79 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:18,874 - Recv:  T:73.63 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:20,873 - Recv:  T:78.86 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:22,873 - Recv:  T:83.56 /0.00 B:20.62 /0.00 @:127 B@:0
2019-12-07 15:31:23,030 - Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793
2019-12-07 15:31:23,031 - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2019-12-07 15:31:23,037 - Changing monitoring state from "Operational" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
2019-12-07 15:31:23,044 - Connection closed, closing down monitor
octolog.zip (3.6 KB)
I guess your firmware crashed.
Did the display reset and show the bootlogo etc?
No, the display was fine. The printer was continuing to run the PID test as far as I can see...the temp was cycling up and down as one would expect.
Interestingly, upgrading to the latest firmware seems to have fixed the issue, whatever it was. For future reference, this is the firmware I successfully built.
https://github.com/bigtreetech/BIGTREETECH-SKR-mini-E3/commit/d983789d72edfa047e4dd1c96eabf5124b088cb2
