I can't figure out how to set up OctoPrint's webcam functionality over WebRTC using MediaMTX on a Raspberry Pi 3 (B+) with a camera module.
I've already gotten MediaMTX to work really nicely. It also works with Prusa Connect Camera. I've also read most of the following thread Low-Latency H264 Streaming Support w/ WebRTC, but no dice. Can't get the preview to appear.
Are there any examples as to what OctoPrint expects from WebRTC webcams or could I just <iframe> the camera stream somehow instead?
Yes you can add an iframe. I was able to create a simple Chrome content script extension that adds the element.
I am not sure what browser you use but I imagine it allows plugins to be developed. Anyways, the core of it is pretty simple:
Hierarchy:
octoprint-mediamtx-extension/
- manifest.json
- content.js
manifest.json:
"manifest_version": 3,
"name": "OctoPrint MediaMTX Stream Injector",
"version": "1.0",
"description": "Injects a MediaMTX WebRTC stream iframe into the OctoPrint webcam section.",
"permissions": [
"activeTab"
"content_scripts": [
"matches": ["http://octopi.local/*"],
"js": ["content.js"],
"run_at": "document_end"
"icons": {
"128": "icon.png"
content.js:
// Create and configure the iframe
const iframe = document.createElement('iframe');
iframe.src = 'http://octopi.local:8889/cam'; // Replace with your MediaMTX WebRTC URL
iframe.width = '640'; // Adjust size as needed
iframe.height = '360';
iframe.style.border = 'none';
// Inject the iframe into the webcam container
const targetElement = document.querySelector('#webcam_plugins_container');
targetElement.appendChild(iframe);
Not pretty but works.
My webcam iframe plugin wouldn't require injecting anything at all.
system
Closed
4
