Halting print a few moves in. It happens at the same point every time, but there seems to be an "ok" missed and the printer just stays in a state of "echo:busy:processing". I cannot cancel, turn off hot end or bed - I just have to kill it at the wall.
Different models - similar initial print duration, then stops. Stops at the same point every time.
Reformatted SD and re-uploaded firmware in a previous state that worked. Reset EEPROM settings, saved and rebooted.
Tried to continue a print using "Fake Acknowledgement" - did nothing still just processing.
Temperatures remain stable, so not waiting for any heating.
Not convinced it was a power issue - never had any problems before, and it stops at exactly the same Gcode every time. I would expect some variation if a power issue?
I am not sure it is a problem with Octoprint.
octoprint-systeminfo-20230608213919.zip (473.8 KB)
Second system info with serial.log turned on (this again has a failed print which has halted):
octoprint-systeminfo-20230608222354.zip (501.9 KB)
Termimal Log of typical failure from start to finish here:
failed print terminal.zip (1.5 KB)
Printer is a Voxelab Aquila, but changed out mainboard for SKR 1.4 with TMC2209 drivers for X,Y,Z,E0 and Z2 on the E1 driver. Firmware is 2.1.x bugfix and zip file with configurations in is attached
Configuration.zip (98.2 KB)
I have adjusted "pins_BTT_SKR_V1_4.h" to open the serial for the LCD DWIN screen as well as the "Conditionals_LCD.h" (this is more for information just in case because was all working fine before).
I am plugged in from Pi Zero 2 running Octoprint via USB to the mainboard.
