The system menu, on the nav bar is missing since I installed Octoprint. I've managed to make the webcam work (start and stop manually). And printed a couple of things.
Read the forums, and documentation.
Logs (octoprint.log, serial.log or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!) octoprint.log (145.1 KB) serial.log (148 Bytes)
Octoprint 1.3.12 in an OrangePi PC+ and Armbian Bionic 5.4.8
Logitech QuickCam, Ender 3 Pro
Firefox 67. Linux Mint, and Android
Originally I copied from a pdf with instructions for the OrangePi. And tried to fix it with 4 spaces since it was evidently wrong. Then after asking here I looked again at the documentation, and noticed the dots that signal spaces, and was able to replicate them, also I originally skipped the "actions:" by mistake.
