- Generic (no label) endoscope
- LogiLink LL1
I followed this video in order to setup my multicam: https://youtu.be/FzpBgEG_ksw
It is mentioned in the video that mjpg-streamer doesn't like to run two instances at the same time and we might to do several reboots to make both cams working. That's exactly what i'm experiencing and I was wondering if there's a fix for this issue.
After pi reboot, cameras randomly fail to start:
pi@octopi:~ $ sudo service webcamd_OverviewCAM status
β webcamd_OverviewCAM.service - the OctoPi webcam daemon with the user specified config
Loaded: loaded (/etc/systemd/system/webcamd_OverviewCAM.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit-hit) since Sat 2021-05-01 02:08:06 EEST; 45s ago
Process: 731 ExecStart=/root/bin/webcamd_OverviewCAM (code=exited, status=0/SUCCESS)May 01 02:08:06 octopi systemd[1]: webcamd_OverviewCAM.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:08:06 octopi systemd[1]: webcamd_OverviewCAM.service: Scheduled restart job, restart counter is at 5.
May 01 02:08:06 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 01 02:08:06 octopi systemd[1]: webcamd_OverviewCAM.service: Start request repeated too quickly.
May 01 02:08:06 octopi systemd[1]: webcamd_OverviewCAM.service: Failed with result 'start-limit-hit'.
May 01 02:08:06 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
pi@octopi:~ $ sudo service webcamd status
β webcamd.service - the OctoPi webcam daemon with the user specified config
Active: failed (Result: start-limit-hit) since Sat 2021-05-01 02:08:06 EEST; 50s ago
Process: 730 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)May 01 02:08:06 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:08:06 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 5.
May 01 02:08:06 octopi systemd[1]: webcamd.service: Start request repeated too quickly.
May 01 02:08:06 octopi systemd[1]: webcamd.service: Failed with result 'start-limit-hit'.
After random amount of reboots (and different combinations of running/failing cameras), they both startup:
Active: active (running) since Sat 2021-05-01 02:09:19 EEST; 2min 2s ago
Process: 373 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
Main PID: 507 (mjpg_streamer)
Tasks: 3 (limit: 4915)
Memory: 3.0M
ββ507 ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8080 -i input_uvc.so -d /dev/endoscopecam -r 640x480 -f 30May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: www-folder-path......: ./www-octopi/
May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: HTTP TCP port........: 8080
May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: HTTP Listen Address..: (null)
May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: username:password....: disabled
May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: commands.............: enabled
May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: starting input plugin input_uvc.so
May 01 02:09:18 octopi mjpg_streamer[507]: MJPG-streamer [507]: starting output plugin: output_http.so (ID: 00)
May 01 02:09:19 octopi webcamd[373]: Done bring up all configured video device
May 01 02:09:19 octopi webcamd[373]: Goodbye...
May 01 02:09:19 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
Active: active (running) since Sat 2021-05-01 02:09:19 EEST; 2min 7s ago
Process: 379 ExecStart=/root/bin/webcamd_OverviewCAM (code=exited, status=0/SUCCESS)
Main PID: 506 (mjpg_streamer)
Tasks: 4 (limit: 4915)
Memory: 3.0M
CGroup: /system.slice/webcamd_OverviewCAM.service
ββ506 ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8081 -i input_uvc.so -d /dev/overviewcam -r 1280x720 -f 30May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: www-folder-path......: ./www-octopi/
May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: HTTP TCP port........: 8081
May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: HTTP Listen Address..: (null)
May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: username:password....: disabled
May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: commands.............: enabled
May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: starting input plugin input_uvc.so
May 01 02:09:18 octopi mjpg_streamer[506]: MJPG-streamer [506]: starting output plugin: output_http.so (ID: 00)
May 01 02:09:19 octopi webcamd_OverviewCAM[379]: Done bring up all configured video device
May 01 02:09:19 octopi webcamd_OverviewCAM[379]: Goodbye...
- In "journalctl -u webcamd" I saw that mjpg is not supported by my endoscope camera so I switched to YUYV. However, even without the "-y" usb option, I noticed that it switched automatically to YUYV so my change shouldn't have made any difference
- I tried many resolutions and framerates
- I read many suggestions to run "vcgencmd get_camera" but when both my cams are running, the result of that command is "supported=1 detected=0"
- I measured the power consumption of the cameras and I am (almost) confident there is no power issue (I saw people suggesting to plug the cameras to a seperately-powered usb hub). My raspberry pi has the 2 cameras and my Ender 3 connected on it (it's a 4B model btw with the official power brick).
Please note that before I switched to multicam, I had only the endoscope camera and it was working properly. I could do "sudo service webcamd restart" and it would work flawlessly. Currently, no matter how many service restarts I execute, the stopped camera(s) will never startup.
Logs (/var/log/webcamd.log
, syslog, dmesg, ... no logs, no support)
Example of a "journalctl -u webcamd" output of a failed startup of my endoscope camera:
pi@octopi:~ $ journalctl -u webcamd
-- Logs begin at Sat 2021-05-01 02:27:29 EEST, end at Sat 2021-05-01 02:28:28 EEST. --
May 01 02:27:33 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
May 01 02:27:33 octopi webcamd[366]: Starting up webcamDaemon...
May 01 02:27:33 octopi webcamd[366]: --- Configuration: ----------------------------
May 01 02:27:33 octopi webcamd[366]: cfg_file: /boot/octopi.txt
May 01 02:27:33 octopi webcamd[366]: camera: usb
May 01 02:27:33 octopi webcamd[366]: usb options: -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:33 octopi webcamd[366]: raspi options: -fps 10
May 01 02:27:33 octopi webcamd[366]: http options: -w ./www-octopi -p 8080
May 01 02:27:33 octopi webcamd[366]: Explicitly USB device:
May 01 02:27:33 octopi webcamd[366]: -----------------------------------------------
May 01 02:27:34 octopi webcamd[366]: Found video devices:
May 01 02:27:34 octopi webcamd[366]: /dev/video0
May 01 02:27:34 octopi webcamd[366]: /dev/video1
May 01 02:27:34 octopi webcamd[366]: /dev/video10
May 01 02:27:34 octopi webcamd[366]: /dev/video11
May 01 02:27:34 octopi webcamd[366]: /dev/video12
May 01 02:27:34 octopi webcamd[366]: /dev/video2
May 01 02:27:34 octopi webcamd[366]: /dev/video3
May 01 02:27:34 octopi webcamd[366]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
May 01 02:27:34 octopi root[489]: Starting USB webcam
May 01 02:27:34 octopi webcamd[366]: <13>May 1 02:27:34 root: Starting USB webcam
May 01 02:27:34 octopi webcamd[366]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8080 -i input_uvc.so -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:34 octopi webcamd[366]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: starting application
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:34 octopi webcamd[366]: i: Using V4L2 device.: /dev/video3
May 01 02:27:34 octopi webcamd[366]: i: Desired Resolution: 640 x 480
May 01 02:27:34 octopi webcamd[366]: i: Frames Per Second.: 30
May 01 02:27:34 octopi webcamd[366]: i: Format............: YUYV
May 01 02:27:34 octopi webcamd[366]: i: JPEG Quality......: 80
May 01 02:27:34 octopi webcamd[366]: i: TV-Norm...........: DEFAULT
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: Using V4L2 device.: /dev/video3
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: Desired Resolution: 640 x 480
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: Frames Per Second.: 30
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: Format............: YUYV
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: JPEG Quality......: 80
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: TV-Norm...........: DEFAULT
May 01 02:27:34 octopi webcamd[366]: Unable to set format: 1448695129 res: 640x480
May 01 02:27:34 octopi webcamd[366]: Init v4L2 failed !! exit fatal
May 01 02:27:34 octopi webcamd[366]: i: init_VideoIn failed
May 01 02:27:34 octopi mjpg_streamer[491]: MJPG-streamer [491]: init_VideoIn failed
May 01 02:27:35 octopi webcamd[366]: Done bring up all configured video device
May 01 02:27:35 octopi webcamd[366]: Goodbye...
May 01 02:27:35 octopi systemd[1]: webcamd.service: Succeeded.
May 01 02:27:35 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
May 01 02:27:35 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:27:35 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 1.
May 01 02:27:35 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 01 02:27:35 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
May 01 02:27:35 octopi webcamd[571]: Starting up webcamDaemon...
May 01 02:27:35 octopi webcamd[571]: --- Configuration: ----------------------------
May 01 02:27:35 octopi webcamd[571]: cfg_file: /boot/octopi.txt
May 01 02:27:35 octopi webcamd[571]: camera: usb
May 01 02:27:35 octopi webcamd[571]: usb options: -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:35 octopi webcamd[571]: raspi options: -fps 10
May 01 02:27:35 octopi webcamd[571]: http options: -w ./www-octopi -p 8080
May 01 02:27:35 octopi webcamd[571]: Explicitly USB device:
May 01 02:27:35 octopi webcamd[571]: -----------------------------------------------
May 01 02:27:35 octopi webcamd[571]: Found video devices:
May 01 02:27:35 octopi webcamd[571]: /dev/video0
May 01 02:27:35 octopi webcamd[571]: /dev/video1
May 01 02:27:35 octopi webcamd[571]: /dev/video10
May 01 02:27:35 octopi webcamd[571]: /dev/video11
May 01 02:27:35 octopi webcamd[571]: /dev/video12
May 01 02:27:35 octopi webcamd[571]: /dev/video2
May 01 02:27:35 octopi webcamd[571]: /dev/video3
May 01 02:27:35 octopi webcamd[571]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
May 01 02:27:35 octopi root[617]: Starting USB webcam
May 01 02:27:35 octopi webcamd[571]: <13>May 1 02:27:35 root: Starting USB webcam
May 01 02:27:35 octopi webcamd[571]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8080 -i input_uvc.so -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: starting application
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:35 octopi webcamd[571]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:35 octopi webcamd[571]: i: Using V4L2 device.: /dev/video3
May 01 02:27:35 octopi webcamd[571]: i: Desired Resolution: 640 x 480
May 01 02:27:35 octopi webcamd[571]: i: Frames Per Second.: 30
May 01 02:27:35 octopi webcamd[571]: i: Format............: YUYV
May 01 02:27:35 octopi webcamd[571]: i: JPEG Quality......: 80
May 01 02:27:35 octopi webcamd[571]: i: TV-Norm...........: DEFAULT
May 01 02:27:35 octopi webcamd[571]: Unable to set format: 1448695129 res: 640x480
May 01 02:27:35 octopi webcamd[571]: Init v4L2 failed !! exit fatal
May 01 02:27:35 octopi webcamd[571]: i: init_VideoIn failed
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: Using V4L2 device.: /dev/video3
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: Desired Resolution: 640 x 480
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: Frames Per Second.: 30
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: Format............: YUYV
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: JPEG Quality......: 80
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: TV-Norm...........: DEFAULT
May 01 02:27:35 octopi mjpg_streamer[618]: MJPG-streamer [618]: init_VideoIn failed
May 01 02:27:36 octopi webcamd[571]: Done bring up all configured video device
May 01 02:27:36 octopi webcamd[571]: Goodbye...
May 01 02:27:36 octopi systemd[1]: webcamd.service: Succeeded.
May 01 02:27:36 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
May 01 02:27:37 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:27:37 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 2.
May 01 02:27:37 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 01 02:27:37 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
May 01 02:27:37 octopi webcamd[625]: Starting up webcamDaemon...
May 01 02:27:37 octopi webcamd[625]: --- Configuration: ----------------------------
May 01 02:27:37 octopi webcamd[625]: cfg_file: /boot/octopi.txt
May 01 02:27:37 octopi webcamd[625]: camera: usb
May 01 02:27:37 octopi webcamd[625]: usb options: -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:37 octopi webcamd[625]: raspi options: -fps 10
May 01 02:27:37 octopi webcamd[625]: http options: -w ./www-octopi -p 8080
May 01 02:27:37 octopi webcamd[625]: Explicitly USB device:
May 01 02:27:37 octopi webcamd[625]: -----------------------------------------------
May 01 02:27:37 octopi webcamd[625]: Found video devices:
May 01 02:27:37 octopi webcamd[625]: /dev/video0
May 01 02:27:37 octopi webcamd[625]: /dev/video1
May 01 02:27:37 octopi webcamd[625]: /dev/video10
May 01 02:27:37 octopi webcamd[625]: /dev/video11
May 01 02:27:37 octopi webcamd[625]: /dev/video12
May 01 02:27:37 octopi webcamd[625]: /dev/video2
May 01 02:27:37 octopi webcamd[625]: /dev/video3
May 01 02:27:37 octopi webcamd[625]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
May 01 02:27:37 octopi root[673]: Starting USB webcam
May 01 02:27:37 octopi webcamd[625]: <13>May 1 02:27:37 root: Starting USB webcam
May 01 02:27:37 octopi webcamd[625]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8080 -i input_uvc.so -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: starting application
May 01 02:27:37 octopi webcamd[625]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:37 octopi webcamd[625]: i: Using V4L2 device.: /dev/video3
May 01 02:27:37 octopi webcamd[625]: i: Desired Resolution: 640 x 480
May 01 02:27:37 octopi webcamd[625]: i: Frames Per Second.: 30
May 01 02:27:37 octopi webcamd[625]: i: Format............: YUYV
May 01 02:27:37 octopi webcamd[625]: i: JPEG Quality......: 80
May 01 02:27:37 octopi webcamd[625]: i: TV-Norm...........: DEFAULT
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: Using V4L2 device.: /dev/video3
May 01 02:27:37 octopi webcamd[625]: Unable to set format: 1448695129 res: 640x480
May 01 02:27:37 octopi webcamd[625]: Init v4L2 failed !! exit fatal
May 01 02:27:37 octopi webcamd[625]: i: init_VideoIn failed
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: Desired Resolution: 640 x 480
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: Frames Per Second.: 30
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: Format............: YUYV
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: JPEG Quality......: 80
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: TV-Norm...........: DEFAULT
May 01 02:27:37 octopi mjpg_streamer[674]: MJPG-streamer [674]: init_VideoIn failed
May 01 02:27:38 octopi webcamd[625]: Done bring up all configured video device
May 01 02:27:38 octopi webcamd[625]: Goodbye...
May 01 02:27:38 octopi systemd[1]: webcamd.service: Succeeded.
May 01 02:27:38 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
May 01 02:27:38 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:27:38 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 3.
May 01 02:27:38 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 01 02:27:38 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
May 01 02:27:38 octopi webcamd[678]: Starting up webcamDaemon...
May 01 02:27:38 octopi webcamd[678]: --- Configuration: ----------------------------
May 01 02:27:38 octopi webcamd[678]: cfg_file: /boot/octopi.txt
May 01 02:27:38 octopi webcamd[678]: camera: usb
May 01 02:27:38 octopi webcamd[678]: usb options: -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:38 octopi webcamd[678]: raspi options: -fps 10
May 01 02:27:38 octopi webcamd[678]: http options: -w ./www-octopi -p 8080
May 01 02:27:38 octopi webcamd[678]: Explicitly USB device:
May 01 02:27:38 octopi webcamd[678]: -----------------------------------------------
May 01 02:27:38 octopi webcamd[678]: Found video devices:
May 01 02:27:38 octopi webcamd[678]: /dev/video0
May 01 02:27:38 octopi webcamd[678]: /dev/video1
May 01 02:27:38 octopi webcamd[678]: /dev/video10
May 01 02:27:38 octopi webcamd[678]: /dev/video11
May 01 02:27:38 octopi webcamd[678]: /dev/video12
May 01 02:27:38 octopi webcamd[678]: /dev/video2
May 01 02:27:38 octopi webcamd[678]: /dev/video3
May 01 02:27:38 octopi webcamd[678]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
May 01 02:27:38 octopi root[723]: Starting USB webcam
May 01 02:27:38 octopi webcamd[678]: <13>May 1 02:27:38 root: Starting USB webcam
May 01 02:27:38 octopi webcamd[678]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8080 -i input_uvc.so -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: starting application
May 01 02:27:38 octopi webcamd[678]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:38 octopi webcamd[678]: i: Using V4L2 device.: /dev/video3
May 01 02:27:38 octopi webcamd[678]: i: Desired Resolution: 640 x 480
May 01 02:27:38 octopi webcamd[678]: i: Frames Per Second.: 30
May 01 02:27:38 octopi webcamd[678]: i: Format............: YUYV
May 01 02:27:38 octopi webcamd[678]: i: JPEG Quality......: 80
May 01 02:27:38 octopi webcamd[678]: i: TV-Norm...........: DEFAULT
May 01 02:27:38 octopi webcamd[678]: Unable to set format: 1448695129 res: 640x480
May 01 02:27:38 octopi webcamd[678]: Init v4L2 failed !! exit fatal
May 01 02:27:38 octopi webcamd[678]: i: init_VideoIn failed
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: Using V4L2 device.: /dev/video3
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: Desired Resolution: 640 x 480
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: Frames Per Second.: 30
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: Format............: YUYV
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: JPEG Quality......: 80
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: TV-Norm...........: DEFAULT
May 01 02:27:38 octopi mjpg_streamer[726]: MJPG-streamer [726]: init_VideoIn failed
May 01 02:27:39 octopi webcamd[678]: Done bring up all configured video device
May 01 02:27:39 octopi webcamd[678]: Goodbye...
May 01 02:27:39 octopi systemd[1]: webcamd.service: Succeeded.
May 01 02:27:39 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
May 01 02:27:40 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:27:40 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 4.
May 01 02:27:40 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 01 02:27:40 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
May 01 02:27:40 octopi webcamd[731]: Starting up webcamDaemon...
May 01 02:27:40 octopi webcamd[731]: --- Configuration: ----------------------------
May 01 02:27:40 octopi webcamd[731]: cfg_file: /boot/octopi.txt
May 01 02:27:40 octopi webcamd[731]: camera: usb
May 01 02:27:40 octopi webcamd[731]: usb options: -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:40 octopi webcamd[731]: raspi options: -fps 10
May 01 02:27:40 octopi webcamd[731]: http options: -w ./www-octopi -p 8080
May 01 02:27:40 octopi webcamd[731]: Explicitly USB device:
May 01 02:27:40 octopi webcamd[731]: -----------------------------------------------
May 01 02:27:40 octopi webcamd[731]: Found video devices:
May 01 02:27:40 octopi webcamd[731]: /dev/video0
May 01 02:27:40 octopi webcamd[731]: /dev/video1
May 01 02:27:40 octopi webcamd[731]: /dev/video10
May 01 02:27:40 octopi webcamd[731]: /dev/video11
May 01 02:27:40 octopi webcamd[731]: /dev/video12
May 01 02:27:40 octopi webcamd[731]: /dev/video2
May 01 02:27:40 octopi webcamd[731]: /dev/video3
May 01 02:27:40 octopi webcamd[731]: config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
May 01 02:27:40 octopi root[780]: Starting USB webcam
May 01 02:27:40 octopi webcamd[731]: <13>May 1 02:27:40 root: Starting USB webcam
May 01 02:27:40 octopi webcamd[731]: Running ./mjpg_streamer -o output_http.so -w ./www-octopi -p 8080 -i input_uvc.so -d /dev/endoscopecam -r 640x480 -f 30 -y
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: starting application
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:40 octopi webcamd[731]: MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
May 01 02:27:40 octopi webcamd[731]: i: Using V4L2 device.: /dev/video3
May 01 02:27:40 octopi webcamd[731]: i: Desired Resolution: 640 x 480
May 01 02:27:40 octopi webcamd[731]: i: Frames Per Second.: 30
May 01 02:27:40 octopi webcamd[731]: i: Format............: YUYV
May 01 02:27:40 octopi webcamd[731]: i: JPEG Quality......: 80
May 01 02:27:40 octopi webcamd[731]: i: TV-Norm...........: DEFAULT
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: Using V4L2 device.: /dev/video3
May 01 02:27:40 octopi webcamd[731]: Unable to set format: 1448695129 res: 640x480
May 01 02:27:40 octopi webcamd[731]: Init v4L2 failed !! exit fatal
May 01 02:27:40 octopi webcamd[731]: i: init_VideoIn failed
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: Desired Resolution: 640 x 480
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: Frames Per Second.: 30
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: Format............: YUYV
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: JPEG Quality......: 80
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: TV-Norm...........: DEFAULT
May 01 02:27:40 octopi mjpg_streamer[781]: MJPG-streamer [781]: init_VideoIn failed
May 01 02:27:41 octopi webcamd[731]: Done bring up all configured video device
May 01 02:27:41 octopi webcamd[731]: Goodbye...
May 01 02:27:41 octopi systemd[1]: webcamd.service: Succeeded.
May 01 02:27:41 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
May 01 02:27:41 octopi systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 01 02:27:41 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 5.
May 01 02:27:41 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 01 02:27:41 octopi systemd[1]: webcamd.service: Start request repeated too quickly.
May 01 02:27:41 octopi systemd[1]: webcamd.service: Failed with result 'start-limit-hit'.
May 01 02:27:41 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
- OctoPrint 1.6.0
- Python 3.7.3
- OctoPi 0.17.0
