I can run cd mjpg-streamer/mjpg-streamer-experimental and ./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so". but I can't get it to run on startup
Well, I followed this tutorial and it did nothing, when I entered sudo systemctl enable webcamd and it gave no output, didn't affect my UI either
β webcamd.service - Camera streamer for OctoPrint
Loaded: loaded (/etc/systemd/system/webcamd.service; enabled; vendor prese>
Active: failed (Result: core-dump) since Sun 2022-01-23 09:41:19 EST; 2min>
Process: 754 ExecStart=/home/liam/scripts/webcamDaemon (code=dumped, signal>
Main PID: 754 (code=dumped, signal=SEGV)
Jan 23 09:41:12 127.0.0.1localhost systemd[1]: Started Camera streamer for Octo>
Jan 23 09:41:19 127.0.0.1localhost systemd[1]: webcamd.service: Main process ex>
Jan 23 09:41:19 127.0.0.1localhost systemd[1]: webcamd.service: Failed with res>
lines 1-9/9 (END)
It indicates that mjpg-streamer is crashing. You said you can run it manually, but have you verified that you can run the script, exactly how the service file would be?
Maybe the files are different on Ubuntu, I did replace pi with my system name, I'm not sure what it is, but I can't test it, my webcams wires got cut, and I have to order a new one.
It's a HP desktop running Ubuntu, I set it to automatically boot octoprint, but I meant the device itself freezes, the cursor doesn't move when I move the mouse. And as I said earlier, the device freezes. I've tried connecting from a separate device, doesn't connect.
Ok I thought you where talking about a different desktop.
Did you start over with a fresh os after tried different tutorials or at least removed everything you did before you started with another one or are you running a mix out of 3 or more tutorials on the same system right now?
That could be the reason why it freezes.
