**What is the problem?**Can not connect printer to PC via USB
Update driver. Used chrome and Microsoft edge browser.
Connecting to: COM3
Changing monitoring state from "Offline" to "Error: Connection error, see Terminal tab"
Unexpected error while connecting to serial port: COM3 SerialException: 'could not open port 'COM3': WindowsError(5, 'Access is denied.')' @ comm.py:_openSerial:2691 (hook default)
Connecting to: COM3
OctoPrint version 1.4.0
not using a Pi trying to connect to PC with windows 10 via USB
Monoprice Maker Select Plus
Thanks for the help in Advance.
octoprint.log (58.4 KB)
