I am trying to print through Octoprint to my Monoprice Maker Ultimate 2. Octoprint connects to the printer without a problem. It can see the SD card and load any of the files on it. Octoprint can also send files that I uploaded to the printer. I can manually move the X/Y/Z axis on the printer through Octoprint. I can turn the fans on and off. I can start a print, but that is where the problem starts. Once I tell octoprint to print, everything looks like it is going well. Everything starts moving around and once the nozzle gets to the bed, Octoprint disconnects says there is an error and the bed immediately drops back to home. On the screen of the printer is the very disconcerting message of:
KILLED.
impresora parada
por favor, reinicie
I can then reboot the printer or tell Octoprint to Connect again and everything is well as long as I do not tell it to print.
I tried turning off the sending checksum but that did not help. I saw this in a video for this printer, but it was with a much older firmware. I am VERY new to 3D printing so I am not sure what else to try.
I can print successfully from the SD card and from Cura through USB on my laptop.This text will be blurred
Octoprint: 1.3.12
Octopi: 0.17.0
Printer: Monoprice Maker Ultimate 2 (Weedo F150S)
Firmware: 2.2.8
Browser: Google Chrome 79.0.3945.117
Operating System: Windows 10 Home 1909
Hardware: Raspberry Pi 4B
EDIT: I have tried running Octoprint in safe mode and it did not make any difference.
It began cooling after that. I'm assuming that I need to manually adjust the PID settings, but I don't really understand where to start. I would appreciate some guidance.
Ok, so I figured out that sending M300 will show you the current PID values. I will follow the wiki you linked and adjust based on their recommendations to see if I can find working values.
The TO in the second post reset the PID values to 0.0 each and ran the autotune again.
You should note your original PID values (M300) and compare them with the autotune run.
@Ewald_Ikemann, thank you again for this pointer. Unfortunately, no matter what values I pick, the autotune fails.
The strange thing is that when printing from SD or USB through Cura, the temp spikes around 20-25 degrees above the target temp everytime and then cools back down to the target temp and prints just fine. I'm guessing this is not normal. Is it Octoprint that kills the print or is it the printer? If it is the printer, I wonder why it does not kill the print from SD or Cura the same?
I don't know if this makes a difference, but I decided to try a hunch.
I set the target temp manually to 150C through Octoprint and let it get to the temp. Once it was stable, I started a print which had the initial temp at 150C. It stopped at the same spot. As soon as the bed raises up to the nozzle, the print gets killed every time, no matter what the temp is.
I even set it at 200C and started the print once it got there knowing it would want to drop to 150C and the print died as soon as the bed got to the nozzle.
I can do the same scenarios with Cura and the SD card and the printer just waits once the bed is fully raised until it gets to a stable target temp and then begins printing.
I'm starting to think I might return this printer and purchase one with a more definite compatibility with Octoprint since that is one of my main interests.
So I started a print and watched the temp. The print stopped before the temp got to the target temp. It is right when the bed and nozzle meet, the print job dies.
i installed also octoprint on my Ubuntu PI. My print with octoprint failed also. Today i printed one file with octoprint and it worked. What was different?
I watched this video and unchecked "Automatic Firmware" and cheecked "never" on checksum
I hope it will be stable.
My Firmware on Monoprice is 2.2.8 and used octoprint 1.5.3
Best
Felix
