On my Mac, I can use Octoprint just fine. This is because I can access the printer easily by doing screen /dev/cu.usbserial-1440 115200 and I can send and view stuff. On my raspberry pi 4 however I cannot.
- I have tried several cables. I know that certain ones work because when I plug them into my Mac, the printer works
- I have a known good power supply that outputs 5v 2 amps.
- I have tried running octoprint on a basic linux machine (same problem).
- I have tried and am using the plugin for Malyan/Monoprice Connection Fix (0.1.3)
Logs (without plugin)
Changing monitoring state from "Offline" to "Opening serial connection"
Connecting to port /dev/ttyUSB0, baudrate 115200
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xae702af0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
No answer from the printer within the connection timeout, trying another hello
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Logs (with Plugin):
Connecting to: /dev/ttyUSB0
Using Malyan/Monoprice Connection Fix Plugin to create serial connection
Connected to: Serial<id=0xaccd4930, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
I can see this on the device:
pi@octopi:~ $ cat /dev/ttyUSB0
�start
echo:PowerUp
Marlin 1.1.5
If I echo stuff to the device I get nothing:
pi@octopi:~ $ echo "N0 M110 N0*125" >> /dev/ttyUSB0
pi@octopi:~ $
I just ordered a new raspberry pi 3 to see if maybe something changed between them to cause this issue.
Yes.
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:91.0) Gecko/20100101 Firefox/91.0
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3959984128
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
