I'm getting M112 when connecting to printer
I see this in the terminal/logs. I've also ran octoprint in safe mode, and connect without any issues. Clearly it's a plugin causing it (and it may be doing so for good reason) but without the details I'm unsure why, and how to fix if possible. I've checked through the logging settings, but not getting the detailed information I need.
Complete Logs
2020-08-03 13:39:49,820 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2020-08-03 13:39:49,821 - octoprint.plugin - DEBUG - Calling on_event on announcements
2020-08-03 13:39:49,822 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2020-08-03 13:39:49,823 - octoprint.plugin - DEBUG - Calling on_event on printer_safety_check
2020-08-03 13:39:49,824 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2020-08-03 13:39:49,825 - octoprint.plugin - DEBUG - Calling on_event on tracking
2020-08-03 13:39:49,826 - octoprint.plugin - DEBUG - Calling on_event on DisplayLayerProgress
2020-08-03 13:39:49,829 - octoprint.plugin - DEBUG - Calling on_event on PrintTimeGenius
2020-08-03 13:39:49,829 - octoprint.plugin - DEBUG - Calling on_event on dashboard
2020-08-03 13:39:49,830 - octoprint.plugin - DEBUG - Calling on_event on display_eta
2020-08-03 13:39:49,831 - octoprint.plugin - DEBUG - Calling on_event on dropbox_timelapse
2020-08-03 13:39:49,831 - octoprint.plugin - DEBUG - Calling on_event on filamentmanager
2020-08-03 13:39:49,832 - octoprint.plugin - DEBUG - Calling on_event on filamentsensorng
2020-08-03 13:39:49,833 - octoprint.plugin - DEBUG - Calling on_event on firmwareupdater
2020-08-03 13:39:49,833 - octoprint.plugin - DEBUG - Calling on_event on octorant
2020-08-03 13:39:49,834 - octoprint.plugin - DEBUG - Calling on_event on tplinksmartplug
2020-08-03 13:39:49,835 - octoprint.plugin - DEBUG - Calling on_event on webcamstreamer
2020-08-03 13:39:52,100 - octoprint.plugins.dashboard - INFO - cmd_results: 9V
2020-08-03 13:39:55,170 - octoprint.plugins.dashboard - INFO - cmd_results: 9V
2020-08-03 13:39:58,237 - octoprint.plugins.dashboard - INFO - cmd_results: 9V
2020-08-03 13:40:01,306 - octoprint.plugins.dashboard - INFO - cmd_results: 9V
2020-08-03 13:40:04,373 - octoprint.plugins.dashboard - INFO - cmd_results: 9V
2020-08-03 13:40:06,713 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2020-08-03 13:40:06,723 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Offline (Error: Closing serial port due to emergency stop M112.)"
From the above, I thought it was .dashboard plugin, as these were some of the last cmds sent, so I disabled these, and got below.
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/plugin/init.py", line 224, in call_plugin
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_filamentsensorng/init.py", line 129, in on_event
GPIO.remove_event_detect(self.pin)
RuntimeError: Please set pin numbering mode using GPIO.setmode(GPIO.BOARD) or GPIO.setmode(GPIO.BCM)
2020-08-03 13:49:02,329 - octoprint.plugin - DEBUG - Calling on_event on firmwareupdater
2020-08-03 13:49:02,329 - octoprint.plugin - DEBUG - Calling on_event on octorant
2020-08-03 13:49:02,330 - octoprint.plugin - DEBUG - Calling on_event on tplinksmartplug
2020-08-03 13:49:02,331 - octoprint.plugin - DEBUG - Calling on_event on webcamstreamer
2020-08-03 13:49:02,779 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': u'local', u'reason': u'error', u'commerror_text': u'Closing serial port due to emergency stop M112.', 'file': 'b68903b5e206ba4b8ed8bec6bb07570a1a6604ab', u'elapsed': 17}
Using
OctoPrint 1.4.0
OctoPi 0.17.0
Snapmaker 2 A350
Firmware Version V1.9.0
Chrome
