After my print the nozzle seems to stay at its final position. It sort of dribbles a but an leaves a blob
Nothing
N/a
Complete Logs
Not sure where to find these. The print finishes ok.
Ender3v2. Petg. But pla did it too. Plugins for bltough, smart filament, tplink smart plug, bed level visualiser, temperatures.
What the end gcode on my TAZ 6 does is retract some filament, move the nozzle up, move the bed to the back of the printer, wait for the bed to cool down, and move the bed to the front of the printer. I've included it below but please adjust it for your own printer dimensions, slicer modes, etc. Note: The variables in {} are replaced by Cura with the appropriate temperature for the material being printed. Substitute appropriate temperatures if you are not using Cura.
M400 ; wait for moves to finish
M140 S{material_part_removal_temperature} ; start bed cooling
M104 S0 ; disable hotend
M107 ; disable fans
G91 ; relative positioning
G1 E-1 F300 ; filament retraction to release pressure
G1 Z20 E-5 X-20 Y-20 F3000 ; lift up and retract even more filament
G1 E6 ; re-prime extruder
M117 Cooling please wait
G90 ; absolute positioning
G1 Y0 F3000 ; move to cooling position
M190 R{material_part_removal_temperature} ; wait for bed to cool down to removal temp
G1 Y280 F3000 ; present finished print
M140 S{material_keep_part_removal_temperature_t} ; keep temperature or cool downs
M77 ; stop GLCD timer
M84 ; disable steppers
M117 Print complete ; progress indicator message
