After completing a print my hot end descends to so and crashes into the model. I get a fail, and then a shutdown
Looked at logs. Don’t understand. I have some lines in post print script.
No, not sure it would help
N/a
Complete Logs
octoprint.log, serial.log or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)</small
2021-02-03 17:30:31,633 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 17:30:31,642 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2021-02-03 17:30:31,642 - octoprint.server - INFO - OctoPrint 1.5.3
2021-02-03 17:30:31,648 - octoprint.plugin.core - INFO - 24 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| Bed Visualizer (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| Creality Temperature (1.2.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_CrealityTemperature
| Creality-2x-temperature-reporting-fix (0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ender3v2tempfix
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| GPIO Shutdown (1.0.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GPIOShutdown
| Pushover (0.3.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_pushover
| Top Temp (0.0.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_toptemp
| TP-Link Smartplug (0.9.26) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_tplinksmartplug
| !Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2021-02-03 17:30:31,664 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 1979641856
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.1
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2021-02-03 17:30:31,664 - octoprint.server - INFO - ------------------------------------------------------------------------------
2021-02-03 17:30:32,161 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 83719}
2021-02-03 17:31:29,059 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.51
2021-02-03 17:31:29,498 - octoprint.server.util.flask - INFO - Passively logging in user tony from ::ffff:192.168.0.51
2021-02-03 17:31:29,500 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 17:31:29,678 - octoprint.server.util.sockjs - INFO - User tony logged in on the socket from client ::ffff:192.168.0.51
2021-02-03 17:38:53,636 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Front_LH_corner_v3.gcode
2021-02-03 17:38:53,640 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/Front_LH_corner_v3.gcode
2021-02-03 17:38:59,256 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Front_LH_corner_v3.gcode finished, needed 5.62s
2021-02-03 17:39:13,819 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-03 17:39:13,847 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2021-02-03 17:39:13,847 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-02-03 17:39:13,848 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-02-03 17:39:13,864 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-02-03 17:39:13,866 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 17:39:13,874 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-02-03 17:39:13,880 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 17:39:13,934 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin E3V2-2.0.x-16-3-Smith3D.M (Jan 13 2021"
2021-02-03 17:39:13,951 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-02-03 17:39:13,970 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2021-02-03 17:39:14,197 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 115200, u'printer_port': None, u'firmware_name': u'Marlin E3V2-2.0.x-16-3-Smith3D.M (Jan 13 2021'}
2021-02-03 17:39:20,504 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Front_LH_corner_v3.gcode, owner: tony, user: tony
2021-02-03 17:39:25,706 - octoprint.util.comm - INFO - Starting job on behalf of user tony
2021-02-03 17:39:25,709 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2021-02-03 17:39:25,728 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Front_LH_corner_v3.gcode, owner: tony, user: tony
2021-02-03 17:39:25,821 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 17:39:25,847 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-02-03 17:39:26,111 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {u'origin': u'local', u'file': 'ba4d4623f1cc4cbc83a637c99b430d6b17ada000'}
2021-02-03 17:39:27,945 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-02-03 17:40:10,920 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2021-02-03 17:40:10,946 - octoprint.plugins.action_command_notification - INFO - Got a notification: Bed Heating...
2021-02-03 17:42:14,286 - octoprint.server.util.flask - INFO - Passively logging in user tony from fe80::44d:c995:e514:cbde
2021-02-03 17:42:14,289 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 17:42:18,760 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::44d:c995:e514:cbde
2021-02-03 17:42:18,846 - octoprint.server.util.flask - INFO - Passively logging in user tony from fe80::44d:c995:e514:cbde
2021-02-03 17:42:18,849 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 17:42:19,418 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2021-02-03 17:42:22,734 - octoprint.server.util.sockjs - INFO - User tony logged in on the socket from client fe80::44d:c995:e514:cbde
2021-02-03 17:42:23,080 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.29s
2021-02-03 17:42:23,613 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.44s
2021-02-03 17:42:24,016 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.37s
2021-02-03 17:42:24,355 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.31s
2021-02-03 17:42:25,014 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.25s
2021-02-03 17:42:25,658 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2021-02-03 17:42:26,940 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2021-02-03 17:42:27,620 - octoprint.plugins.softwareupdate - WARNING - Unknown update check type for target smartfilamentsensor: <n/a>
2021-02-03 17:42:28,744 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2021-02-03 17:45:31,638 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 17:45:32,181 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 84619}
2021-02-03 18:00:31,640 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:00:32,276 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 85519}
2021-02-03 18:10:17,134 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.0.51
2021-02-03 18:15:31,642 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:15:32,149 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 86419}
2021-02-03 18:18:13,069 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::44d:c995:e514:cbde
2021-02-03 18:26:55,309 - octoprint.server.util.flask - INFO - Passively logging in user tony from fe80::44d:c995:e514:cbde
2021-02-03 18:26:55,311 - octoprint.access.users - INFO - Cleaning up user session 35B87F82D0FD4144B11251181D9CABF5 for user tony
2021-02-03 18:26:55,315 - octoprint.access.users - INFO - Logged out user: tony
2021-02-03 18:26:55,320 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 18:27:09,936 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::44d:c995:e514:cbde
2021-02-03 18:27:10,165 - octoprint.server.util.flask - INFO - Passively logging in user tony from fe80::44d:c995:e514:cbde
2021-02-03 18:27:10,167 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 18:27:13,597 - octoprint.server.util.sockjs - INFO - User tony logged in on the socket from client fe80::44d:c995:e514:cbde
2021-02-03 18:27:15,644 - octoprint.plugins.softwareupdate - WARNING - Unknown update check type for target smartfilamentsensor: <n/a>
2021-02-03 18:28:04,306 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::44d:c995:e514:cbde
2021-02-03 18:30:31,645 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:30:32,277 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 87319}
2021-02-03 18:45:31,647 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 18:45:32,206 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 88219}
2021-02-03 19:00:31,649 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 19:00:32,205 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 89119}
2021-02-03 19:15:31,651 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 19:15:32,270 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 90019}
2021-02-03 19:30:31,653 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 19:30:32,209 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 90919}
2021-02-03 19:37:05,892 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Printer halted. kill() called!
| Last lines in terminal:
| Recv: ok
| Send: N58387 G1 X5 Y215*43
| Recv: T:243.83 /244.00 B:60.01 /60.00 @:93 B@:25
| Recv: ok
| Send: N58388 G28 Z0*87
| Recv: echo:busy: processing
| Recv: T:243.75 /244.00 B:60.00 /60.00 @:92 B@:28
| Recv: T:243.75 /244.00 B:60.00 /60.00 @:91 B@:28
| Recv: T:244.30 /244.00 B:60.00 /60.00 @:77 B@:28
| Recv: T:245.00 /244.00 B:59.97 /60.00 @:61 B@:37
| Recv: T:243.75 /244.00 B:59.99 /60.00 @:95 B@:33
| Recv: T:243.75 /244.00 B:60.00 /60.00 @:92 B@:29
| Recv: T:243.75 /244.00 B:60.00 /60.00 @:91 B@:30
| Recv: Error:Printer halted. kill() called!
2021-02-03 19:37:05,896 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error: Printer halted. kill() called!"
2021-02-03 19:37:05,906 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2021-02-03 19:37:05,955 - octoprint.util.comm - INFO - Changing monitoring state from "Error: Printer halted. kill() called!" to "Offline (Error: Printer halted. kill() called!)"
2021-02-03 19:37:06,365 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_firmware, payload: {u'commerror_text': u'Printer halted. kill() called!'}
2021-02-03 19:37:21,046 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {u'origin': u'local', u'reason': u'error', u'commerror_text': u'Printer halted. kill() called!', u'file': 'ba4d4623f1cc4cbc83a637c99b430d6b17ada000', u'elapsed': 7060}
2021-02-03 19:37:22,543 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-03 19:37:22,550 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-03 19:44:00,079 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::44d:c995:e514:cbde
2021-02-03 19:44:00,189 - octoprint.server.util.flask - INFO - Passively logging in user tony from fe80::44d:c995:e514:cbde
2021-02-03 19:44:00,192 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 19:44:00,345 - octoprint.server.util.sockjs - INFO - User tony logged in on the socket from client fe80::44d:c995:e514:cbde
2021-02-03 19:44:05,247 - tornado.access - WARNING - 400 POST /api/connection (fe80::44d:c995:e514:cbde) 37.34ms
2021-02-03 19:44:11,261 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-03 19:44:17,406 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-03 19:44:30,259 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-03 19:44:30,280 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
2021-02-03 19:44:30,281 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2021-02-03 19:44:30,282 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2021-02-03 19:44:30,301 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-02-03 19:44:30,303 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 19:44:32,529 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2021-02-03 19:44:32,533 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 19:44:32,557 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-02-03 19:44:32,565 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 19:44:32,670 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin E3V2-2.0.x-16-3-Smith3D.M (Jan 13 2021"
2021-02-03 19:44:32,688 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-02-03 19:44:32,700 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2021-02-03 19:44:33,095 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 115200, u'printer_port': u'AUTO', u'firmware_name': u'Marlin E3V2-2.0.x-16-3-Smith3D.M (Jan 13 2021'}
2021-02-03 19:44:42,669 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: top_corner.gcode, owner: tony, user: tony
2021-02-03 19:44:48,489 - octoprint.util.comm - INFO - Starting job on behalf of user tony
2021-02-03 19:44:48,500 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2021-02-03 19:44:48,511 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: top_corner.gcode, owner: tony, user: tony
2021-02-03 19:44:48,626 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-02-03 19:44:48,656 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-02-03 19:44:49,091 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {u'origin': u'local', u'file': '245a654af8fd8f45bccadf76df7641c332bfed4f'}
2021-02-03 19:44:50,761 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-02-03 19:44:58,173 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::44d:c995:e514:cbde
2021-02-03 19:45:20,749 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2021-02-03 19:45:20,769 - octoprint.plugins.action_command_notification - INFO - Got a notification: Bed Heating...
2021-02-03 19:45:31,656 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 19:45:32,207 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 91819}
2021-02-03 20:00:31,658 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 20:00:32,196 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 92719}
2021-02-03 20:15:31,662 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 20:15:32,285 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 93619}
2021-02-03 20:20:17,793 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::44d:c995:e514:cbde
2021-02-03 20:20:17,950 - octoprint.server.util.flask - INFO - Passively logging in user tony from fe80::44d:c995:e514:cbde
2021-02-03 20:20:17,951 - octoprint.access.users - INFO - Logged in user: tony
2021-02-03 20:20:18,418 - octoprint.server.util.sockjs - INFO - User tony logged in on the socket from client fe80::44d:c995:e514:cbde
2021-02-03 20:23:18,061 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::44d:c995:e514:cbde
2021-02-03 20:30:31,664 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-03 20:30:32,218 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 94519}
2021-02-03 20:44:30,277 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Printer halted. kill() called!
| Recv: ok
| Send: N26635 G1 X5 Y215*46
| Recv: ok
| Send: N26636 G28 Z0*94
| Recv: T:246.80 /247.00 B:69.99 /70.00 @:89 B@:48
| Recv: T:247.50 /247.00 B:70.00 /70.00 @:74 B@:45
| Recv: T:247.42 /247.00 B:70.00 /70.00 @:78 B@:45
| Recv: T:246.95 /247.00 B:70.00 /70.00 @:90 B@:45
| Recv: T:246.25 /247.00 B:70.00 /70.00 @:105 B@:45
| Recv: T:246.33 /247.00 B:70.00 /70.00 @:101 B@:45
| Recv: T:247.50 /247.00 B:70.00 /70.00 @:73 B@:45
| Recv: T:247.50 /247.00 B:70.00 /70.00 @:75 B@:45
2021-02-03 20:44:30,279 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error: Printer halted. kill() called!"
2021-02-03 20:44:30,289 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2021-02-03 20:44:30,350 - octoprint.util.comm - INFO - Changing monitoring state from "Error: Printer halted. kill() called!" to "Offline (Error: Printer halted. kill() called!)"
2021-02-03 20:44:30,689 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_firmware, payload: {u'commerror_text': u'Printer halted. kill() called!'}
2021-02-03 20:44:39,964 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {u'origin': u'local', u'reason': u'error', u'commerror_text': u'Printer halted. kill() called!', u'file': '245a654af8fd8f45bccadf76df7641c332bfed4f', u'elapsed': 3581}
*** truncated here***
Latest octoprint. Ender 3v2. Pi4.
