Hey guys,
I had used Octopi in the past (around april) without any problems and my MP Mini Delta... I haven't printed in a while and kind of forgot things lol. I'm trying to print something right now and I can't get the octopi to connect to mp mini delta. I remember back in april there was a bug where you had to click connect, disconnect and connect again... then it would work. It was something suggested here. Well I can't get it to connect to my mp mini delta at all now. cables are plugged in (nothing has been really touched) but nogo. I'm able to connect to octopi, but not octopi to printer. Any help?
I'm on OctoPrint 1.3.9 running on OctoPi 0.15.0
output on terminal tab once I click connect...
I don't know how to get the output log and serial log?
Serial port list: ['/dev/ttyACM0']
Connecting to: /dev/ttyACM0
Connected to: Serial<id=0x75fe7db0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Send: N0 M110 N0125
Baudrate test retry #1
Send: N0 M110 N0125
Baudrate test retry #2
Send: N0 M110 N0125
Baudrate test retry #3
Send: N0 M110 N0125
Baudrate test retry #4
Send: N0 M110 N0125
Trying baudrate: 250000
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying baudrate: 230400
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0*125
Closing down send loop
