Running on macOS 10.13.6 (High Sierra)
OctoPrint : 1.4.0
Malyan/Monoprice Connection Fix Plugin : 0.1.3
Repetier-Host-Mac: Version 1.2.0 (105)
Python 3.7.7
OctoPrint's terminal:
Connecting to: /dev/tty.usbmodemFD1251
Using Malyan/Monoprice Connection Fix Plugin to create serial connection
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x100fe5fd0, open=True>(port='/dev/tty.usbmodemFD1251', baudrate=57600, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N1 M110 N1*125
No answer from the printer within the connection timeout, trying another hello
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Repetier-Host-Mac's terminal:
7:27:23 PM: Attempting to connect to printer
7:27:23 PM: Connection opened
> 7:27:23 PM: N1 M110 *2
< 7:27:23 PM: ok N0 P15 B15 T:21.4 /0.0 B:25.0 /0.0 T0:21.4 /0.0 @:0 B@:0
> 7:27:23 PM: N2 M115 *4
< 7:27:23 PM: ok N1 P15 B15
< 7:27:23 PM: NAME. Malyan VER: 3.7 MODEL: M300 HW: HG01
< 7:27:23 PM: BUILD: Jun 22 2017 20:42:15
< 7:27:23 PM: ok N2 P15 B15
> 7:27:23 PM: N4 M111 S6 *67
< 7:27:23 PM: ok N3 P15 B15 T:22.5 /0.0 B:23.8 /0.0 T0:22.5 /0.0 @:0 B@:0
> 7:27:23 PM: N5 M111 S6 *66
< 7:27:23 PM: ok N4 P15 B15
< 7:27:23 PM: ok N5 P15 B15
< 7:27:23 PM: ok N6 P15 B15 T:22.0 /0.0 B:24.1 /0.0 T0:22.0 /0.0 @:0 B@:0
< 7:27:24 PM: ok N7 P15 B15 T:20.5 /0.0 B:21.8 /0.0 T0:20.5 /0.0 @:0 B@:0
The problem seems obvious to me: OctoPrint is sending the wrong commands.
How do I change them to match Repetier-Host ?
