MP select mini v2 won’t connect to Octo print
Tried installing Maylan/MP connection problem plugin for octo print
Tried many different cables including ones that were definitely data transfer cables rather than just power
Yes
My printer usually has a USB indicator showing on the UI that there is a cable connected but it just won’t indicate it on the printer screen, maybe this is a problem with my printer, this may not be the place to talk about printer problems(not relating to octo print) which this may be. But someone might be able to help?
