Logitech c920 and generic USB cam (endoscope)
Multicam is installed. Everything seems to be working fine but the Switch buttons in the Control Tab don't work. The camera's have different aspect ratio's and you can see that it switches form 16:9 to 4:3 and back but the video feed is only of the Logitech camera. The url of the stream does work and (really strange) the Octopod app on my phone switches between the cameras as expected.
I tried to switch the cameras, I reinstalled Multicam a couple of times, I used different server addresses (octopi.local, 192.168... 127.0.0.0 etc). Nothing seems to work.
webcam.log:
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1920x1080 -f 10 -d /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_79D6FCDF-video-index0
raspi options: -fps 10
Explicitly USB device: /dev/v4l/by-id/usb-046d_HD_Pro_Webcam_C920_79D6FCDF-video-index0
cfg_file: /boot/octopi.conf.d/webcam2.txt
camera: usb
usb options: -r 640x480 -f 10 -d /dev/v4l/by-id/usb-Generic_USB2.0_PC_CAMERA-video-index0
http options: -w ./www-octopi -n -p 8081
Explicitly USB device: /dev/v4l/by-id/usb-Generic_USB2.0_PC_CAMERA-video-index0
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video2
/dev/video3
config file='/boot/octopi.txt':USB device was set in options and found in devices, start MJPG-streamer with th$
<13>Oct 25 09:00:34 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1920x1080 -$
i: Using V4L2 device.: /dev/video2
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
Octoprint version: 1.8.6
