I'm trying to install two logitech quickcam . If I set the first one (wedcam2.txt) up with port 8081 and the second (webcam3.txt) with port 8082 the second doesn't work, but if I unplug webcam2 and reboot webcam3 works but on the webcam2 button
the line of code i've changed in ssh WEBCAM2.txt
camera="usb"
camera_usb_options="-r 640x480 -f 10 -d /dev/v4l/by-id/usb-046d_0991_803151F5-video-index0"
camera_http_options="-n -p 8081"
WEBCAM3.txt
camera="usb"
camera_http_options="-n -p 8082"
Edit your configuration files webcam2, webcam3, ...
And use the paths you've previously copied.
Don't forget to add "/dev/v4l/by-path/" before, and the -d parameter.
Configuration example for my webcam2 configuration file:
