Hello everyone,
Here is my problem:
I followed your tutorial for the installation of two cameras, a C170 and a "nor tech" full HD (from action - 9$).
After a few manipulations everything worked perfectly.
Given the quality of the nor tec camera, I decided to get a second one and replace the ageing logitech.
The problem is that the two cameras are strictly identical and have the same id:
usb-Jieli_Technology_USB_PHY_2.0-video-index0
ls /dev/v4l/by-id
usb-Jieli_Technology_USB_PHY_2.0-video-index1
If I unplug one of the two cameras, it works correctly and is displayed in octoprint.
I tried a workaround with :
ls /dev/v4l/by-path
platform-bcm2835-codec-video-index0
platform-bcm2835-isp-video-index0
platform-bcm2835-isp-video-index1
platform-bcm2835-isp-video-index2
platform-bcm2835-isp-video-index3
platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-video-index0
platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-video-index1
platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0
platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index1
I can see my two cameras (usb-0:1.2:1.0-video-index0 / usb-0:1.3:1.0-video-index0)
I configured my conf files like this:
octopi.txt
camera="usb
camera_usb_options="-r 1920x1080 -f 10 /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-video-index0"
#camera_http_webroot="./www-octopi"
#camera_http_options="-n"
webcam2.txt
camera="usb
camera_usb_options="-r 1920x1080 -f 10 /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0-video-index0"
camera_http_options="-n -p 8081"
I've also tried changing the usb port, but that didn't fix the problem
no
deleted
OCTOPRINT Version 1.9.1
lsusb result :
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 1224:2a25
Bus 001 Device 003: ID 1224:2a25
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
webcamd.log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 1920x1080 -f 10 /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0$
raspi options: -fps 10
Explicitly USB device:
cfg_file: /boot/octopi.conf.d/webcam2.txt
camera: usb
usb options: -r 1920x1080 -f 10 /dev/v4l/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3:1.0$
http options: -w ./www-octopi -n -p 8081
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video2
/dev/video3
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first fou$
<13>Jul 7 22:40:49 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1920x$
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 10
i: Format............: JPEG
i: FPS coerced ......: from 10 to 25
o: HTTP Listen Address..: 127.0.0.1
config file='/boot/octopi.conf.d/webcam2.txt':USB device was not set in options, start MJPG-streamer wit$
<13>Jul 7 22:40:50 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -p 8081 -i input_uvc.so -r 1920x1080 -f 10 $
i: Using V4L2 device.: /dev/video1
Unable to set format: 1196444237 res: 1920x1080
Thanks for any help you can give me ![]()
