IMX219 Arducam
Sonix USB Camera
I'd like to stream a camera to each instance
Tried adding camera using sudo add-usb-camera (USBCamera) (Used ports 5001, same as instance or 8006, what the instance tried to use through paukstelis' [octoprint_deploy](https://github.com/paukstelis/octoprint_deploy), as well as 8081)
I also tried to edit /boot/camera-streamer/usb-USBCamera.conf and changing the ports there. I also have tried the same with libcamera considering I have a raspicam.
I've been trying to figure this out just looking at various txt files etc. I just don't know how I setup a camera w/ a port on top of a instance that already has a port. I'm able to get as far as setting up instances with no camera output. Please let me know how I can do this.
libcamera.log (770 Bytes)
usb-USBCamera.log (489 Bytes)
config.log (2.2 KB)
octopi.log (1.3 KB)
octoprint_deploy.log (3.3 KB)
Actual log: WacBl-gITvg - paste.octoprint.org
I don't have a webcamd.log, I believe that's something that was removed when adding camera-streamer. If there's another log I could upload, let me know.
OctoPi 1.0.0 with OctoPrint 1.8.7 20230328122604
Arducam IMX219
Generic Webcam
Ender 3 Pro w/ SKR Mini E3 V3
Ender 5 Plus w/ SKR Mini E3 V3
