I can't access the 2nd instance, I get error 404
or
Access octopi through the settings in haproxy, but it is always the same instance, even changing IP, Port and Home Directory.
1°- I recorded a Sd card configuration from scratch without changes.
2°- I copied the folder: "/home/pi/.octoprint/" to "/home/pi/.octoprint2/"
3°- I copied the file "/etc/systemd/system/octoprint.service" to "/etc/systemd/system/octoprint2.service"
4°- with "nano" I edited the file "octoprint2.service" with the following change: "ExecStart=/home/pi/oprint/bin/octoprint serve --host=${HOST} --port=${PORT} --config /home/pi/.octoprint2/config.yaml --basedir /home/pi/.octoprint2"
5°- with nano I edited the file "/etc/haproxy/haproxy.cfg" with the following change: "frontend public
bind :::80 v4v6
bind :::443 v4v6 ssl crt /etc/ssl/snakeoil.pem
use_backend octoprint2 if { path_beg /octoprint2/ }
use_backend webcam_hls if { path_beg /hls/ }
use_backend webcam_hls if { path_beg /jpeg/ }
default_backend octoprintoctoprint backend
acl needs_scheme req.hdr_cnt(X-Scheme) eq 0reqrep ^([^\ :]*)\ /(.*) \1\ /\2 reqadd X-Scheme:\ https if needs_scheme { ssl_fc } reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc } option forwardfor server octoprint1 127.0.0.1:5000 errorfile 503 /etc/haproxy/errors/503-no-octoprint.httpoctoprint2 backend
acl needs_scheme req.hdr_cnt(X-Scheme) eq 0reqrep ^([^\ :]*)\ /octoprint2/(.*) \1\ /\2 reqadd X-Scheme:\ https if needs_scheme { ssl_fc } reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc } option forwardfor server octoprint1 0.0.0.0:5001 errorfile 503 /etc/haproxy/errors/503-no-octoprint.http"
6° - I gave the commands:
> sudo systemctl enable octoprint2.service
> sudo systemctl start octoprint2.service
> sudo service haproxy reload
> sudo reboot now
### Have you tried running in safe mode?
no
### Did running in safe mode solve the problem?
no
### Systeminfo Bundle
<small>You can download this in OctoPrint's System Information dialog ... **no bundle, no support!**)</small>
[octoprint-systeminfo-20220816115319.zip|attachment](upload://yPMNM3JXirDqOPq2EP9IB9687s3.zip) (254.4 KB)
### Additional information about your setup
<small>OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... **as much data as possible**</small>
