503 Errors while attempting to access 2nd printers' page
Unable to name USB ports.
Printers connection randomly timing out if left idle.
Changed HAproxy settings to every solution known to google.
Changed second instance settings to every solution known to google.
Changing udev rules several times.
Adjusted long-running command time.
OctoPi version 1.3.9
Raspberry Pi 3 B+
Creality Ender 3
iMaker STARTT
I don't have access to the logs at this moment, I will post them when I can, if required.
