I understand the reasons not to run multiple instances on one pi. I'm migrating to Octofarm bc I have too many printers, like one does. I'm willing to consider a pi per printer but I'm shooting for the cheapest way to go. I'm guessing that the Rpi 3B+ is the way to go? Is there a cheaper functional option? I'd try the zero w but for many many reasons this whole farm is wired not wifi.
What kind of printers do you have? I mean, a dozen Prusas or three $85 Monoprice deltas?
A bit of a hodgepodge really: Ender 5, CR6-SE, MPSM, MPMD, Lottmax Shark (Dual), and a couple of tenlog dual hotend printers
For now at least
I have multiple instances of octoprint on my rpi 4. They were working properly. Now, I can start instance 2 at port 5001 but the original will not start with port 5000 or without any port number. When I enter my ip address 192.168.1.210 or 210:5000 I get an unable to connect message. If I enter 192.168.1.210:5001 it connects without any problems.
I double checked all of the settings on my rpi.
When I connect to instance 2 I can change the USB port and connect to the printer on instance 1 but it is still on port 5001, not 5000.
I cannot get that far.
Complete Logs
OctoPrint version 1.5.2, OctoPi version 0.17.0, printer CR-10s, firmware, browser: chrome and firefox, operating system, Windows 10 as much data as possible
To quote the message template: "No logs? No support!"
It's hard to know without any logs.
Ultimately you should be in this thread, though:
If octoprint wont start you cannot get a log file.
You say "didn't start", it appears that means the web service didn't come up. Much would emit logs before that, there should be some startup noise.
How are you starting it?
Ok, I’m using wrong terminology and got some more information this morning. I turn on both of my printers and wait for them to boot up. Then I turn my Pi on and the printers re-boot. I put the ip address in my web browser and instance 2 at port 5001 comes up but instance 1 at port 5000 will not connect. In Chrome I get the message “This site can’t be reached 192.168.1.210 refused to connect. I did a status check on octoprint and octoprint2, both shows they are running. I tried stopping and restarting octoprint but I still cannot connect with my web browser. I use Putty to access the rPi so if there is a way to get log through Putty I can do that.
Gary Struckmeier
Email address removed by mod
This post shows where the logs are on all platforms:
Thank you for all your help. I finally decided it would be quicker to just do a clean install and start fresh.
Gary Struckmeier
I have the same problem, did you find a solution?
We need more information.
Which OS are you using? Did you use a guide to set it up and if yes which one?
Hello! Install it following the guide of cris
Octoprint On Linux - Install - How To - Chris's Basement - YouTube.
and for the instances
Octoprint On Linux - Revisit - Multiple Instance Install - Chris's Basement - YouTube.
I want to add 10 instances with the same producer id, vendor id and serial.
I should do it through the usb port but I don't know how to do it
I think that's going to make it difficult to assign udev rules or serial port assignment mappings I think.
Do you think it is not possible?
I need to do it xD. Connect a usb hub and identify the ports but I don't know if it is possible
A month and a half late, but it is certainly possible. You just have to use KERNELS defined rules in udev and keep everything plugged into the same ports/hub positions.
I want to make a few clarifications since, right now, a Pi is rather expensive and often hard to find, so the option of running 2 printers on one Pi is attractive.
First, I've seen power mentioned a few times. That includes saying a Pi can't handle running 2 printers at the same time, but it sounds like more people have done this and find it works. Can anyone verify for me they've used 1 Pi to control 2 printers, both printing at the same time? Did it work or were there issues?
Second, I haven't seen anyone discuss using a touchscreen. Is it possible to use a touchscreen connected to a Pi using 2 (or more) instances of OctoPi to control their printers from a touchscreen? While I do a lot of my work from a nearby desktop, it'd be really nice to have a touchscreen at my print station so I don't have to go back and forth for some work. (And along that line, it looks like there are touchscreen interfaces designed for smaller touchscreens for a Pi. Can anyone tell me what smaller sized touchscreen they use and if it works easily for them with OctoPi?)
Hello! Thanks for the reply. Yes, I was able to connect 8 instances to a pi but I have problems. My sd fills up very quickly since it uses the memory of the pi
switch to a usb thumb drive maybe
