I just flashed a new SD with 0.17.0
My backup from 0.15.(1 or 2?) will not restore correctly. It keeps timing out.
I made sure everything is up to date on the new instance
Yes and no
Complete Logs
octoprint.log (47.5 KB)
plugin_softwareupdate_console.log (20.5 KB)
serial.log (148 Bytes)
Brand new install flashed today
Can someone look at my logs please and tell me what I'm missing?
I can't see anything in your logs that shows that the backup is making it to the server, so maybe it is client side it fails.
Couple of questions:
- How large is the backup? I have seen it where a 3GB backup was too large (too many timelapses)
- Have a look in the browser error console - maybe there is something there.
- Can you try a different browser?
It’s close to 2 GB
There are no browser errors.
I’m using Chrome but I’ll try a different one.
FWIW, I tried a different backup (by accident) and it worked fine.
I finally got it to work but I had to restore 3 backups back and then move forward one at a time from there. It's odd. Also something about reverting to py 2.7, restoring, then upgrading to py 3
