Changing monitoring state from "Offline" to "Opening serial connection"
Changing monitoring state from "Opening serial connection" to "Error: Connection error, see Terminal tab"
Changing monitoring state from "Error: Connection error, see Terminal tab" to "Offline (Error: Connection error, see Terminal tab)"
Unexpected error while connecting to serial port /dev/ttyACM0, baudrate 115200 from hook GPX: IOError: '[Errno 2] No such file or directory: u'/home/pi/.octoprint/data/GPX/gpx.ini'' @ comm.py:_open_serial:2784
Performing autodetection with 4 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyUSB0@115200, /dev/ttyUSB0@250000
Trying port /dev/ttyACM0, baudrate 115200
Could not open port /dev/ttyACM0, baudrate 115200, skipping
Trying port /dev/ttyACM0, baudrate 250000
Unexpected error while connecting to serial port /dev/ttyACM0, baudrate 250000 from hook GPX: IOError: '[Errno 2] No such file or directory: u'/home/pi/.octoprint/data/GPX/gpx.ini'' @ comm.py:_open_serial:2784
Could not open port /dev/ttyACM0, baudrate 250000, skipping
Trying port /dev/ttyUSB0, baudrate 115200
Unexpected error while connecting to serial port /dev/ttyUSB0, baudrate 115200 from hook GPX: IOError: '[Errno 2] No such file or directory: u'/home/pi/.octoprint/data/GPX/gpx.ini'' @ comm.py:_open_serial:2784
Could not open port /dev/ttyUSB0, baudrate 115200, skipping
Trying port /dev/ttyUSB0, baudrate 250000
Unexpected error while connecting to serial port /dev/ttyUSB0, baudrate 250000 from hook GPX: IOError: '[Errno 2] No such file or directory: u'/home/pi/.octoprint/data/GPX/gpx.ini'' @ comm.py:_open_serial:2784
Could not open port /dev/ttyUSB0, baudrate 250000, skipping
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: <octoprint_GPX.gpxprinter.GpxPrinter instance at 0xad98dc10>, starting monitor
Send: N0 M110 N0*125
Recv: start
Recv: Makerbot v7.4
Recv: echo: gcode to x3g translation by GPX
Recv: SD init fail
Recv: T:30 /0 B:23 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Recv: ok
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Makerbot FIRMWARE_VERSION:7.4 FIRMWARE_URL:https://support.makerbot.com/learn/earlier-products/replicator-original/updating-firmware-for-the-makerbot-replicator-via-replicatorg_13302 MACHINE_TYPE:r1d EXTRUDER_COUNT:2
Send: N2 M21*18
Recv: Cap:EMERGENCY_PARSER:1
Recv: ok
Recv: SD init fail
Changing monitoring state from "Operational" to "Offline"
Connected to: <octoprint_GPX.gpxprinter.GpxPrinter instance at 0xad9fd620>, starting monitor
Recv: start
Recv: Makerbot v7.4
Recv: SD init fail
Recv: T:31 /0 B:23 /0 T0:31 /0 T1:31 /0 @:0 B@:0
Recv: ok
Recv: ok
Recv: ok
Send: N1 M115*39
Send: N2 M21*18
Recv: ok
Recv: SD init fail
Send: M105
Recv: ok T:30 /0 B:23 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Send: M105
Recv: ok T:30 /0 B:23 /0 T0:30 /0 T1:30 /0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:31 /0 B:23 /0 T0:31 /0 T1:31 /0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: G91
Recv: ok
Send: G28 X0 Y0
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G28 X0 Y0
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G28 Z0
Recv: T:30 /0 B:24 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:30 /0 B:26 /0 T0:30 /0 T1:30 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:30 /0 B:26 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G28 X0 Y0
Recv: T:30 /0 B:26 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Recv: T:31 /0 B:26 /0 T0:31 /0 T1:30 /0 @:0 B@:0
Recv: T:30 /0 B:26 /0 T0:30 /0 T1:30 /0 @:0 B@:0
Recv: T:30 /0 B:25 /0 T0:30 /0 T1:30 /0 @:0 B@:0
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:31 /0 B:24 /0 T0:31 /0 T1:31 /0 @:0 B@:0
Send: M105
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 X-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:31 /0 B:25 /0 T0:31 /0 T1:30 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 X10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:30 /0 B:25 /0 T0:30 /0 T1:30 /0 @:0 B@:0
Send: M105
Recv: ok T:31 /0 B:25 /0 T0:31 /0 T1:31 /0 @:0 B@:0
Send: M105
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: M105
Send: M105
Recv: ok T:30 /0 B:25 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Send: M105
Send: T1
Recv: ok
Send: M105
Send: M105
Send: G91
Recv: ok
Send: G1 Y10 F6000
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:31 /0 B:25 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:31 /0 B:26 /0 T0:31 /0 T1:31 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-10 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:31 /0 B:26 /0 T0:30 /0 T1:31 /0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: G91
Recv: ok
Send: G1 Z10 F200
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Changing monitoring state from "Operational" to "Starting"
Recv: ok
Send: (@build "201901MosaicKeychain1")
Recv: ok
Send: N1 M136 (201901MosaicKeychain1)*61
Recv: ok
Send: N2 G92 X0 Y0 Z0 A0 B0*88
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: ?\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?\x00\x00\x00\x00201901MosaicKeychain1\x00?\x00\x00?\x00?\x03~\x01\x00\x00\x14\x00?\x04?\x00\x00\x00\x14\x00?\x00\x00\x00\x00\x00\x00\x00\x000???\x00\x00\x00\x00\x00\x00\x00\x00?\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00x\x1e\x00\x00\x1b\x00\x00?@?\x04?\x04?\x05\x00\x00\x14\x00?\x1f??????????.\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00J\x00\x00\x00?\x00\x14?\x01\x14?\x02\x14?\x03\x14?\x04\x14?\x00\x03\x02?\x00?\x01\x00?\x00d\x00???\x05\x00?\x00\x7f?\x01\x7f?\x02(?\x03\x7f?\x04\x7f??????????.\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00??????????\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00x\x1e\x00\x00\x18???A?\x04??????????\x00\x00\x00????\x00\x00\x00\x00?\x01\x00\x00\x18\x00\x00?A@\x01?d???????<\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?\x04\x00\x00\x18aj?@\x00\x05? ???n????\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?\x04\x00\x00\x18\x1b??@\x00\x05? ???n????\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00? ???n????\x00\x00\x00?\x00\x00\x00\x00\x00\x00\x00?\x07\x00\x00\x1833??\x00\x05? ???n????\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?\x00\x03\x02?\x00?? \x00\x00,????\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x013\x00\x00\x18?\x1a'C?%?? \x00\x00,???L\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00x\x1e\x00\x00\x18\x00\x00?>?\x04?? \x00\x00,???L\x00\x00\x00y???\x00\x00\x00\x00?\x07\x00\x00\x1833??\x00\x05?? \x00\x007???L\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x16 \x00\x00\x18?3\x07>f\x06?? \x00\x00[???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?Q?>f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18??(?f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?\x14
Recv: ok
Send: ?f\x06?? \x00\x00\x00???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?\x14(?f\x06?? \x00\x00j???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18B$??f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00z\x08\x00\x00\x18\x03\x03??f\x06?? \x00\x005???L\x00\x00\x00????\x00\x00\x00\x00
Recv: // echo: (line 2) Syntax error: unrecognised gcode '?'
Recv: ok
Send: \x08\x00\x00\x18\x16???f\x06?N \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?g??f\x06?\x0c \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18????f\x06??\x08\x00\x001???L\x00\x00\x00????\x00\x00\x00\x00Q\x06\x00\x00\x18!???f\x06?j\x08\x00\x00w???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18o$??f\x06?\x0e\x08\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?^??f\x06??\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00
Recv: // echo: (line 3) Syntax error: unrecognised gcode '?f\x06?? '
Recv: ok
Send: \x08\x00\x00\x18?.??f\x06?C\x07\x00\x00\x03???L\x00\x00\x00????\x00\x00\x00\x00n\x08\x00\x00\x18???f\x06??\x06\x00\x00\x1a???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x10???f\x06?q\x06\x00\x00$???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18/B??f\x06?I\x06\x00\x00%???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18r\x04?>f\x06??\x05\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18\x7f?@f\x06??\x04\x00\x00G???L\x00\x00\x00????\x00\x00\x00\x00w\x08\x00\x00\x18?\x05Af\x06?\x01\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00\x1d\x08\x00\x00\x18lfS@f\x06?[\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?\x00??f\x06??\x06\x00\x00\x1d???L\x00\x00\x00????\x00\x00\x00\x00d\x07\x00\x00\x18Q???f\x06??\x06\x00\x00Y???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18K???f\x06?!\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18\x06???f\x06?Q\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18???f\x06?s\x07\x00\x00=???L\x00\x00\x00????\x00\x00\x00\x00#\x08\x00\x00\x18??~?f\x06??\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?6??f\x06??\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?]??f\x06??\x07\x00\x00J\x00\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x11?~?f\x06??\x07\x00\x00?\x00\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?\x00??f\x06?J\x07\x00\x00^\x01\x00\x00L\x00\x00\x00????\x00\x00\x00\x00|\x08\x00\x00\x18??\x0c@f\x06?\x1a\x04\x00\x00&\x0b\x00\x00L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18a\x06?Af\x06?\x06\x00??\x03\x00\x00?\x0c\x00\x00L\x00\x00\x00????\x00\x00\x00\x00r\x08\x00\x00\x18N??@f\x06?f\x03\x00\x00/
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00\x11\x08\x00\x00\x18M?g?f\x06?7\x03\x00\x00s
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00\\x07\x00\x00\x18`?l?f\x06??\x02\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00i\x06\x00\x00\x18??s?f\x06??\x02\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00\x1d\x07\x00\x00\x18??t?f\x06?m\x02\x00\x00\x0b\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?9w?f\x06?\x1c\x02\x00\x00&\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00q\x08\x00\x00\x189?u?f\x06??\x01\x00\x003\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18.Lf?f\x06?{\x01\x00\x003\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18??m?f\x06?(\x01\x00\x00&\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x0fWr?f\x06??\x00\x00\x00\x0b\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00u\x08\x00\x00\x18?4x?f\x06??\x00\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?{t?f\x06?J\x00\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00\x17\x07\x00\x00\x18??j?f\x06?\x0f\x00\x00\x00u
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00j\x06\x00\x00\x18?Us?f\x06?????/
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00M\x07\x00\x00\x18\x02hu?f\x06??????\x0c\x00\x00L\x00\x00\x00????\x00\x00\x00\x00\x02\x08\x00\x00\x18??o?f\x06?R????\x05\x00\x00L\x00\x00\x00????\x00\x00\x00\x00q\x08\x00\x00\x18?"?Af\x06?????\x0c???L\x00\x00\x00????\x00\x00\x00\x00q\x08\x00\x00\x18s
Recv: ok
Send: ?Af\x06?o???\x00???L\x00\x00\x00????\x00\x00\x00\x00\x0e\x08\x00\x00\x18??>f\x06?V???\x11???L\x00\x00\x00????\x00\x00\x00\x00!\x08\x00\x00\x18>]?@f\x06?
Recv: ok
Send: ???????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18??|?f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00\x03\x07\x00\x00\x18????f\x06?????m???L\x00\x00\x00????\x00\x00\x00\x00e\x06\x00\x00\x18#\x1b??f\x06?R???$???L\x00\x00\x00????\x00\x00\x00\x008\x07\x00\x00\x18?d??f\x06?(???????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18????f\x06?\x01???a???L\x00\x00\x00????\x00\x00\x00\x00r\x08\x00\x00\x18x???f\x06? ???????L\x00\x00\x00????\x00\x00\x00\x00x\x08\x00\x00\x18$?\x06Af\x06?\x0f???@???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?M??f\x06?
Recv: // echo: (line 14) Syntax error: unrecognised gcode '?Af\x06?o???'
Recv: ok
Send: ???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x04&v?f\x06?\x12???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18ye??f\x06?'???8???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?-??f\x06?G???????L\x00\x00\x00????\x00\x00\x00\x00C\x08\x00\x00\x18?\x17??f\x06?w???????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18<0??f\x06?????I???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18???f\x06?????\x0b???L\x00\x00\x00????\x00\x00\x00\x00d\x06\x00\x00\x18@\x1c??f\x06?9???????L\x00\x00\x00????\x00\x00\x00\x00>\x07\x00\x00\x186???f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?|?f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00[\x08\x00\x00\x181>~?f\x06?4???\x7f???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x11\x12??f\x06?????z???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18r???f\x06??\x02\x00\x00z???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18???Af\x06??\x02\x00\x00\x15???L\x00\x00\x00????\x00\x00\x00\x00d\x08\x00\x00\x18|\x11??f\x06?\x10\x03\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00\x00\x08\x00\x00\x18??f\x06?K\x03\x00\x00W???L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18l??f\x06??\x03\x00\x00\x03???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18?l??f\x06??\x03\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00R\x06\x00\x00\x18>??f\x06?2\x04\x00\x00s???L\x00\x00\x00????\x00\x00\x00\x00\x06\x07\x00\x00\x18\x0cY??f\x06??\x04\x00\x00:???L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18???f\x06??\x04\x00\x00
Recv: // echo: (line 15) Syntax error: unrecognised gcode '???????L'
Recv: ok
Send: ???L\x00\x00\x00????\x00\x00\x00\x00\x1b\x08\x00\x00\x18??f\x06?[\x05\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18y\x12??f\x06??\x05\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18[9??f\x06?6\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18.0??f\x06??\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x027??f\x06?\x0c\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x14???f\x06?v\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18X???f\x06??\x07\x00\x00&???L\x00\x00\x00????\x00\x00\x00\x005\x08\x00\x00\x18???f\x06?=\x08\x00\x00\???L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18s???f\x06??\x08\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00B\x07\x00\x00\x18???f\x06??\x08\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18?q??f\x06?0 \x00\x007???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18?D??f\x06?n \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00N\x07\x00\x00\x18_`??f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18cA??f\x06?? \x00\x00[???L\x00\x00\x00????\x00\x00\x00\x00P\x08\x00\x00\x18????f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?\x07&?f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18d\x13\x0c?f\x06?? \x00\x00\x01???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?%9?f\x06?? \x00\x00$???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18c??>f\x06?? \x00\x00,???L\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00a \x00\x00\x18X??=f\x06?? \x00\x00,???L\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00?4\x00\x00\x18UZ?>?%?? \x00\x008???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?F >f\x06?? \x00\x00\???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18.??>f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?\x11+?f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18??f\x06?? \x00\x00g???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18l???f\x06?? \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00o\x08\x00\x00\x18???f\x06?_ \x00\x002???L\x00\x00\x00????\x00\x00\x00\x00\x00\x08\x00\x00\x18????f\x06?& \x00\x00????L\x00\x00\x00????\x00\x00\x00\x00w\x07\x00\x00\x18\x0e???f\x06??\x08\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18????f\x06??\x08\x00\x00)???L\x00\x00\x00????\x00\x00\x00\x00j\x06\x00\x00\x18????f\x06?>\x08\x00\x00j???L\x00\x00\x00????\x00\x00\x00\x00\x18\x07\x00\x00\x18???f\x06??\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18\???f\x06??\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00"\x08\x00\x00\x18????f\x06?\x18\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18F???f\x06??\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18 O??f\x06?C\x06\x00\x00\x01???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?w??f\x06?3\x06\x00\x00\x01???L\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00# \x00\x00\x18?y>>f\x06?,\x06\x00\x00\x0c???L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18e?\x13>f\x06??\x04\x00\x00W???L\x00\x00\x00????\x00\x00\x00\x00u\x08\x00\x00\x18\x18?OAf\x06??\x04\x00\x00`???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18??\x18>f\x06?/\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00\x1d\x08\x00\x00\x18\x1dn?@f\x06?z\x06\x00\x00(???L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?R|?f\x06??\x06\x00\x00^???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18??u?f\x06??\x06\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18c?\x7f?f\x06?(\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00h\x07\x00\x00\x18????f\x06?M\x07\x00\x00<???L\x00\x00\x00????\x00\x00\x00\x00\x1b\x08\x00\x00\x18R?\x7f?f\x06?f\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18b^??f\x06?r\x07\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18??y?f\x06?q\x07\x00\x00?\x00\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?n|?f\x06?d\x07\x00\x00?\x00\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18=?s?f\x06?
Recv: // echo: (line 16) Syntax error: unrecognised gcode '???????L'
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18?=?Af\x06?h\x03\x00\x00?\x0c\x00\x00L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18:\x1c?@f\x06?H\x03\x00\x00\x1b
Recv: // echo: (line 17) Syntax error: unrecognised gcode '???L'
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00 \x08\x00\x00\x18??[?f\x06?\x19\x03\x00\x00_
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00a\x07\x00\x00\x18\x1d?k?f\x06??\x02\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00m\x06\x00\x00\x18?\x03g?f\x06??\x02\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x001\x07\x00\x00\x18\x04ag?f\x06?[\x02\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?\x16a?f\x06?\x10\x02\x00\x00\x04\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00x\x08\x00\x00\x18a?b?f\x06??\x01\x00\x00\x10\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x16?e?f\x06?p\x01\x00\x00\x0e\x0e\x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18??k?f\x06? \x01\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18Cjj?f\x06??\x00\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00Z\x08\x00\x00\x18??\?f\x06??\x00\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18??c?f\x06?W\x00\x00\x00?
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18??\?f\x06?!\x00\x00\x00R
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18?[f?f\x06?????\x12
Recv: ok
Send: \x00\x00L\x00\x00\x00????\x00\x00\x00\x00j\x07\x00\x00\x18\x03?\?f\x06??????\x0c\x00\x00L\x00\x00\x00????\x00\x00\x00\x00-\x08\x00\x00\x18.?W?f\x06?????????L\x00\x00\x00n???\x00\x00\x00\x00r\x08\x00\x00\x18?V@Bf\x06?e???????L\x00\x00\x00????\x00\x00\x00\x00 \x08\x00\x00\x181_?@f\x06?\x1a???????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18??{?f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18L8??f\x06?????K???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18h\x04??f\x06?h???\x04???L\x00\x00\x00????\x00\x00\x00\x00b\x07\x00\x00\x18?*v?f\x06?B???????L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?(}?f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00v\x08\x00\x00\x18?>@f\x06?A???????L\x00\x00\x00????\x00\x00\x00\x00z\x08\x00\x00\x18??@f\x06?1???5???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18??{?f\x06?.???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18:\x15??f\x06?8???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x0e?{?f\x06?P???,???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x1b<??f\x06?s???????L\x00\x00\x00????\x00\x00\x00\x00!\x08\x00\x00\x18\x1a?{?f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00z\x07\x00\x00\x18ta??f\x06?????L???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18???f\x06? ???\x12???L\x00\x00\x00????\x00\x00\x00\x00?\x06\x00\x00\x18g?\x7f?f\x06?h???????L\x00\x00\x00????\x00\x00\x00\x00~\x07\x00\x00\x18}?u?f\x06?????????L\x00\x00\x00????\x00\x00\x00\x00\x1e\x08\x00\x00\x18?F??f\x06?\x10???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18M?\x7f?f\x06?h???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?/~?f\x06?y???????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18?G
Recv: ok
Send: Af\x06??\x02\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18???Af\x06??\x02\x00\x00????L\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x7f\x07\x00\x00\x18?y?=f\x06??\x02\x00\x006???L\x00\x00\x00????\x00\x00\x00\x00?\x08\x00\x00\x18\x17??f\x06?'\x03\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00\x1d\x08\x00\x00\x18?\x05??f\x06?^\x03\x00\x00y???L\x00\x00\x00????\x00\x00\x00\x00?\x07\x00\x00\x18?k??f\x06??\x03\x00\x00'???L\x00\x00\x00????\x00\x00\x00\x00\x05\x07\x00\x00\x18?}??f\x06??\x03\x00\x00????L\x00\x00\x00????\x00\x00\x00\x00S\x06\x00\x00\x18???f\x06?
Recv: ok
Send: \x04\x00\x00`\x02\x00\x00L\x00\x00\x00????\x00\x00\x00\x00|\x08\x00\x00\x18k}??f\x06??\x03\x00\x00?\x02\x00\x00L\x00\x00\x00????\x00\x00\x00\x00t\x08\x00\x00\x18\x18???f\x06??\x03\x00\x00?\x04\x00\x00L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18?\x19?@f\x06??\x02\x00\x00?\x06\x00\x00L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18?a?@f\x06?\x07\x02\x00\x00?\x08\x00\x00L\x00\x00\x00????\x00\x00\x00\x00u\x08\x00\x00\x18\x01??@f\x06??\x01\x00\x00? \x00\x00L\x00\x00\x00????\x00\x00\x00\x00s\x08\x00\x00\x18W?[@f\x06??\x01\x00\x00?
ctc replicator dual extrder
WRITE HERE gpx
