OctoPrint won't run the service on windows 10 since a reboot.
Manually Rebooting server, starting and restarting the service. Setting the service to manual start rather than automatic
Yes
No Change
Service Wrapper Log
2023-07-10 13:37:41,582 DEBUG - Starting WinSW in service mode
2023-07-10 13:37:41,660 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:37:41,714 INFO - Started process 5800
2023-07-10 13:37:41,714 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:37:55,361 DEBUG - Starting WinSW in service mode
2023-07-10 13:37:55,391 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:37:55,424 INFO - Started process 10784
2023-07-10 13:37:55,429 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:38:13,019 DEBUG - Starting WinSW in service mode
2023-07-10 13:38:13,046 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:38:13,074 INFO - Started process 12136
2023-07-10 13:38:13,074 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:38:25,825 DEBUG - Starting WinSW in service mode
2023-07-10 13:38:25,851 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:38:25,876 INFO - Started process 9272
2023-07-10 13:38:25,880 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:38:38,576 DEBUG - Starting WinSW in service mode
2023-07-10 13:38:38,604 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:38:38,628 INFO - Started process 12888
2023-07-10 13:38:38,632 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:38:51,395 DEBUG - Starting WinSW in service mode
2023-07-10 13:38:51,430 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:38:51,463 INFO - Started process 11892
2023-07-10 13:38:51,467 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:39:04,624 DEBUG - Starting WinSW in service mode
2023-07-10 13:39:04,651 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:39:04,677 INFO - Started process 9260
2023-07-10 13:39:04,681 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:39:17,543 DEBUG - Starting WinSW in service mode
2023-07-10 13:39:17,571 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:39:17,595 INFO - Started process 10684
2023-07-10 13:39:17,599 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:39:30,460 DEBUG - Starting WinSW in service mode
2023-07-10 13:39:30,488 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:39:30,514 INFO - Started process 12436
2023-07-10 13:39:30,518 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:39:43,397 DEBUG - Starting WinSW in service mode
2023-07-10 13:39:43,429 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:39:43,453 INFO - Started process 7024
2023-07-10 13:39:43,456 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:39:55,413 DEBUG - Starting WinSW in console mode
2023-07-10 13:39:56,235 DEBUG - Starting WinSW in service mode
2023-07-10 13:39:56,264 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:39:56,291 INFO - Started process 7176
2023-07-10 13:39:56,295 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:39:57,066 DEBUG - Starting WinSW in console mode
2023-07-10 13:39:57,266 INFO - Starting service 'OctoPrint on Port 5000 (OctoPrint5000)'...
2023-07-10 13:39:57,272 INFO - Service 'OctoPrint on Port 5000 (OctoPrint5000)' has already started.
2023-07-10 13:40:08,931 DEBUG - Starting WinSW in service mode
2023-07-10 13:40:08,959 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:40:08,987 INFO - Started process 12024
2023-07-10 13:40:08,992 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:40:21,820 DEBUG - Starting WinSW in service mode
2023-07-10 13:40:21,850 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:40:21,874 INFO - Started process 5456
2023-07-10 13:40:21,878 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:40:34,341 DEBUG - Starting WinSW in service mode
2023-07-10 13:40:34,368 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:40:34,391 INFO - Started process 3000
2023-07-10 13:40:34,394 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:40:47,109 DEBUG - Starting WinSW in service mode
2023-07-10 13:40:47,136 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:40:47,169 INFO - Started process 11968
2023-07-10 13:40:47,172 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:40:59,739 DEBUG - Starting WinSW in service mode
2023-07-10 13:40:59,766 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:40:59,790 INFO - Started process 2296
2023-07-10 13:40:59,794 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:41:12,275 DEBUG - Starting WinSW in service mode
2023-07-10 13:41:12,302 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:41:12,327 INFO - Started process 8588
2023-07-10 13:41:12,330 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:41:24,775 DEBUG - Starting WinSW in service mode
2023-07-10 13:41:24,805 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:41:24,833 INFO - Started process 10368
2023-07-10 13:41:24,836 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:41:37,272 DEBUG - Starting WinSW in service mode
2023-07-10 13:41:37,303 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:41:37,330 INFO - Started process 13248
2023-07-10 13:41:37,334 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:41:49,736 DEBUG - Starting WinSW in service mode
2023-07-10 13:41:49,767 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:41:49,792 INFO - Started process 1752
2023-07-10 13:41:49,796 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:41:59,073 DEBUG - Starting WinSW in service mode
2023-07-10 13:41:59,104 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:41:59,132 INFO - Started process 12400
2023-07-10 13:41:59,136 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:02,381 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:02,411 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:02,438 INFO - Started process 13096
2023-07-10 13:42:02,442 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:11,662 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:11,689 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:11,717 INFO - Started process 10464
2023-07-10 13:42:11,721 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:14,886 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:14,913 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:14,936 INFO - Started process 1712
2023-07-10 13:42:14,940 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:24,227 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:24,253 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:24,276 INFO - Started process 10364
2023-07-10 13:42:24,280 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:27,356 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:27,383 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:27,406 INFO - Started process 13036
2023-07-10 13:42:27,409 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:36,742 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:36,767 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:36,790 INFO - Started process 8712
2023-07-10 13:42:36,793 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:39,899 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:39,924 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:39,947 INFO - Started process 12372
2023-07-10 13:42:39,950 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:49,155 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:49,181 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:49,204 INFO - Started process 11484
2023-07-10 13:42:49,207 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:42:52,339 DEBUG - Starting WinSW in service mode
2023-07-10 13:42:52,366 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:42:52,389 INFO - Started process 7548
2023-07-10 13:42:52,392 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:43:01,609 DEBUG - Starting WinSW in service mode
2023-07-10 13:43:01,635 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:43:01,658 INFO - Started process 10644
2023-07-10 13:43:01,661 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:43:04,815 DEBUG - Starting WinSW in service mode
2023-07-10 13:43:04,843 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:43:04,866 INFO - Started process 12740
2023-07-10 13:43:04,870 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:44:03,552 DEBUG - Starting WinSW in service mode
2023-07-10 13:44:03,626 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:44:03,674 INFO - Started process 5700
2023-07-10 13:44:03,674 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:44:17,738 DEBUG - Starting WinSW in service mode
2023-07-10 13:44:17,754 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:44:17,791 INFO - Started process 11040
2023-07-10 13:44:17,791 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:44:33,315 DEBUG - Starting WinSW in service mode
2023-07-10 13:44:33,344 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:44:33,361 INFO - Started process 11080
2023-07-10 13:44:33,361 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:44:45,902 DEBUG - Starting WinSW in service mode
2023-07-10 13:44:45,939 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:44:45,957 INFO - Started process 12832
2023-07-10 13:44:45,964 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:44:58,347 DEBUG - Starting WinSW in service mode
2023-07-10 13:44:58,382 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:44:58,404 INFO - Started process 13136
2023-07-10 13:44:58,408 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:45:10,791 DEBUG - Starting WinSW in service mode
2023-07-10 13:45:10,822 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:45:10,842 INFO - Started process 11048
2023-07-10 13:45:10,858 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:45:23,389 DEBUG - Starting WinSW in service mode
2023-07-10 13:45:23,420 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:45:23,447 INFO - Started process 11580
2023-07-10 13:45:23,447 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:45:35,978 DEBUG - Starting WinSW in service mode
2023-07-10 13:45:36,008 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:45:36,029 INFO - Started process 13252
2023-07-10 13:45:36,029 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:45:48,484 DEBUG - Starting WinSW in service mode
2023-07-10 13:45:48,519 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:45:48,544 INFO - Started process 1740
2023-07-10 13:45:48,544 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:45:51,715 DEBUG - Starting WinSW in console mode
2023-07-10 13:45:53,372 DEBUG - Starting WinSW in console mode
2023-07-10 13:45:53,392 INFO - Installing service 'OctoPrint on Port 5000 (OctoPrint5000)'...
2023-07-10 13:45:53,392 ERROR - A service with ID 'OctoPrint5000' already exists.
2023-07-10 13:45:53,392 FATAL - Failed to install the service. The specified service already exists
2023-07-10 13:45:59,839 DEBUG - Starting WinSW in console mode
2023-07-10 13:46:00,997 DEBUG - Starting WinSW in service mode
2023-07-10 13:46:01,026 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:46:01,051 INFO - Started process 7696
2023-07-10 13:46:01,055 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:46:01,455 DEBUG - Starting WinSW in console mode
2023-07-10 13:46:01,686 INFO - Starting service 'OctoPrint on Port 5000 (OctoPrint5000)'...
2023-07-10 13:46:01,686 INFO - Service 'OctoPrint on Port 5000 (OctoPrint5000)' has already started.
2023-07-10 13:46:13,534 DEBUG - Starting WinSW in service mode
2023-07-10 13:46:13,558 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:46:13,589 INFO - Started process 13248
2023-07-10 13:46:13,589 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:46:26,086 DEBUG - Starting WinSW in service mode
2023-07-10 13:46:26,130 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:46:26,167 INFO - Started process 4376
2023-07-10 13:46:26,167 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:46:38,910 DEBUG - Starting WinSW in service mode
2023-07-10 13:46:38,927 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:46:38,944 INFO - Started process 2340
2023-07-10 13:46:38,961 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:46:51,323 DEBUG - Starting WinSW in service mode
2023-07-10 13:46:51,342 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:46:51,362 INFO - Started process 1404
2023-07-10 13:46:51,362 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:03,696 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:03,729 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:03,761 INFO - Started process 10340
2023-07-10 13:47:03,764 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:09,856 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:09,872 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:09,892 INFO - Started process 1480
2023-07-10 13:47:09,909 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:15,308 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:15,327 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:15,345 INFO - Started process 12056
2023-07-10 13:47:15,362 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:22,217 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:22,251 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:22,269 INFO - Started process 11492
2023-07-10 13:47:22,269 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:27,663 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:27,698 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:27,715 INFO - Started process 12228
2023-07-10 13:47:27,715 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:34,646 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:34,681 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:34,699 INFO - Started process 2604
2023-07-10 13:47:34,699 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:40,088 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:40,105 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:40,122 INFO - Started process 9324
2023-07-10 13:47:40,138 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:47,044 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:47,070 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:47,090 INFO - Started process 1496
2023-07-10 13:47:47,090 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:52,474 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:52,491 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:52,523 INFO - Started process 2332
2023-07-10 13:47:52,524 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:47:59,560 DEBUG - Starting WinSW in service mode
2023-07-10 13:47:59,578 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:47:59,596 INFO - Started process 7788
2023-07-10 13:47:59,612 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:04,838 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:04,875 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:04,897 INFO - Started process 3940
2023-07-10 13:48:04,897 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:11,993 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:12,020 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:12,044 INFO - Started process 12696
2023-07-10 13:48:12,048 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:17,283 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:17,313 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:17,340 INFO - Started process 8248
2023-07-10 13:48:17,344 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:24,490 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:24,521 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:24,552 INFO - Started process 10656
2023-07-10 13:48:24,552 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:29,837 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:29,868 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:29,915 INFO - Started process 13008
2023-07-10 13:48:29,915 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:37,008 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:37,046 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:37,072 INFO - Started process 10104
2023-07-10 13:48:37,072 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:42,506 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:42,521 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:42,553 INFO - Started process 13240
2023-07-10 13:48:42,553 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:49,520 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:49,551 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:49,582 INFO - Started process 4040
2023-07-10 13:48:49,582 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:48:55,110 DEBUG - Starting WinSW in service mode
2023-07-10 13:48:55,142 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:48:55,157 INFO - Started process 7292
2023-07-10 13:48:55,173 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:02,001 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:02,032 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:02,048 INFO - Started process 8692
2023-07-10 13:49:02,063 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:07,633 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:07,664 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:07,695 INFO - Started process 2984
2023-07-10 13:49:07,695 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:14,540 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:14,571 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:14,587 INFO - Started process 6320
2023-07-10 13:49:14,603 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:20,216 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:20,247 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:20,278 INFO - Started process 9760
2023-07-10 13:49:20,278 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:27,026 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:27,057 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:27,089 INFO - Started process 11828
2023-07-10 13:49:27,089 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:32,704 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:32,735 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:32,762 INFO - Started process 3956
2023-07-10 13:49:32,765 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:39,514 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:39,545 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:39,572 INFO - Started process 9308
2023-07-10 13:49:39,575 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
2023-07-10 13:49:45,192 DEBUG - Starting WinSW in service mode
2023-07-10 13:49:45,223 INFO - Starting C:\OctoPrint\WPy64-31050\Scripts\python.bat -m octoprint serve --basedir="C:\OctoPrint\basedir\5000" --port 5000
2023-07-10 13:49:45,239 INFO - Started process 11372
2023-07-10 13:49:45,239 DEBUG - Forwarding logs of the process System.Diagnostics.Process (cmd) to WinSW.IgnoreLogAppender
Octoprint is running on a Windows 10 Bare metal server. 32GB ram, SSD, Intel Xeon Processor. Browser used is Edge, and chrome
