it seems to act first and then print. but it doesn't do that.
I rebooted and looked at gcode settings. but the problem does not appear.
yes
no
octoprint.log (3.0 MB)
octoprint last version- prusa slicer and cura cr10 smart
I noticed octoprint is not installed with the standard user pi but under /home/ali/.octoprint/
This is not recommended and regularly leads to problems unless you do a lot of post install reconfiguration.
Your best path might be to go back to flashing octopi and not change the user from the default pi.
I don't see a safe mode start in the log file, but there are a lot of plugin errors generally. Do you have one from when you tested it in safe mode?
I did what you said, formatted and printed the pattern again. I will test again now and post the result. Thanks for help.
I just tried and uploaded the log file before. but it is not working. Also, which plugins did you see?
system
Closed
September 27, 2022, 10:47am
6
