Whenever i click the load and print button, it wont do anything. No response at all, and it basically looks like i never clicked it in the first place. This happened after an update to UI Customizer, although even though i disabled it, it still has the issue.
Disabled UI Customizer, Restarted OctoPrint
Yes
No, same issues as before
Complete Logs
2021-03-27 23:06:59,097 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: V2__Mini_Folding_Knife_non_serrated_Blade_NEW_0.2mm_PLA_ENDER3_1h14m.gcode,
owner: RioWolf, user: RioWolf
2021-03-27 23:06:59,119 - octoprint - ERROR - Exception on /api/files/local/V2__Mini_Folding_Knife_non_serrated_Blade_NEW_0.2mm_PLA_ENDER3_1h14m.gcode [POST]
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 2447, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1952, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1821, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1950, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1936, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/flask.py", line 1539, in decorated_view
return func(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/api/files.py", line 802, in gcodeFileCommand
printer.select_file(filenameToSelect, sd, printAfterLoading, user)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/printer/standard.py", line 680, in select_file
tags=kwargs.get("tags", set()) | {"trigger:printer.select_file"},
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 1599, in selectFile
filename, self._currentFile.getFilesize(), False, user=user
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/printer/standard.py", line 1545, in on_comm_file_selected
self._setJobData(full_path, size, sd, user=user)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/printer/standard.py", line 1282, in _setJobData
and "estimatedPrintTime" in fileData["analysis"]
TypeError: argument of type 'NoneType' is not iterable
i couldn't get complete logs, but this is what came from when i clicked the button, so i hope its enough.
version 1.5.3
my plugins are:
AstroPrint]
Bed Leveling Wizard
Firmware Check
OctoEverywhere!
Octolapse
Printer Dialogs
Printer Notifications
Simple Emergency Stop
Slicer Print Time Estimator
Top Temp
Virtual Printer
my printer is an ender 3 pro and my web browser is brave, and i run windows.
