Using python2.7 it appears to fail when it gets to "setuptools" and given the ticking clock on python2 I'd rather use python3 anyway.
Used update-alternatives to change the default python to 3.5.2 and updated pip to 20.0.2 and pip install now fails to find the package at all: 'pip -p /usr/bin/python3 install octoprint' returns "ERROR: Could not find a version that satisfies the requirement octoprint (from versions: none) ERROR: No matching distribution found for octoprint" even though "pip search octoprint" returns a line "OctoPrint (1.4.0) - The snappy web interface for your 3D printer" I also tried 'pip install OctoPrint' with the same results.
I also downloaded the 1.4.0.zip file from github and extracted it to /oprint/oprint/OctoPrint-1.4.0. When I activate a virtualenv into the OctoPrint-1.4.0. If I cd into that dir and run 'pip install .' I get an error "Processing /oprint/oprint/OctoPrint-1.4.0 ERROR: Package 'OctoPrint' requires a different Python: 3.5.2 not in '>=2.7.9, !=3.0., !=3.1., !=3.2., !=3.3., !=3.4., !=3.5., <4'
3.5.2 is not included in 3.5*? My regex knowledge but be getting rusty.
NanoPi Neo quad-core ARM 1.2GHz with 512MB RAM and Ubuntu Core 16.04LTS. I won't be using a webcam and have seen mention of others using this for OctoPrint.
'pip install octoprint' reported these along the way:
"ERROR: Failed building wheel for regex"
"ERROR: Failed building wheel for netifaces"
"ERROR: Failed building wheel for psutil"
and then later failed hard when it couldn't find regex:
BTW, can't find the logs mentioned. Even after:
root@oprint:/oprint/oprint# updatedb
root@oprint:/oprint/oprint# locate octoprint
nothing in /var/log and if I run pip install octoprint while I have journalctl -f running nothing related appears...
more info:
realized I hadn't installed python3.6-venv when I installed python3.6 but after doing that and logging out & back in got the same results, failed to build wheels for those three packages and then the install failed when it tried to use regex.
also realized that after a fresh start I'd failed to upgrade pip but at v20 I get the same errors on the same three packages
should I be running some different pip for python3.6? can't find anything in apt-cache search that seems likely beyond python3-pip (I have that)
