Need assistance w/ Monoprice Cadet
Cannot get OctoPrint to connect to the Monoprice Cadet 3D printer (product link)
  • Tried automatic detection, got Error: No more baudrates to test, and no suitable baudrate found.
  • Could not find any documentation detailing the required baudrate for the printer over USB (manual).
  • Selected /dev/ttyUSB0
  • Have tried all of the baudrates, some of which result in gibberesh sent back, others send back nothing at all.
Details
  • OctoPrint Version 1.4.0
  • Printer is an IIIP printer
It is a mystery to me why people asking for help supply everything in the template but...
Hint: note that logs above are links to a document that details how to find and supply them.
Logs for 250000 baudrate:
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6a972bb0, open=True>(port='/dev/ttyUSB0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: 1\x95\x961¥\x95%\x01!%¡!\x94\x84\x05\x11\x08
Recv: -¯¡51¡-\x10\xffÔ!çõ\xffÆ\xff-¡1¡!á!1\xff1\xff-0±\xff-0±\xff·\xff·\xff¯¡%õ\x14¤\x08\x94Ñ\x10F\xff±\x10\x08¡õ\x10\x081\xff0\x12nVF\xff¡0\x12\x86V\x08\x84\xff0\x12\x86VF\xff1ú0\x12\x86\x16÷F\xff1ú0\x12\x86\x16÷\x08¡0½R\x08!ú0\x90F\xffñõ°\x80Vç\x86\xff°F\xff\x84\xff°\x02F\xff!Õ\x8e\x10F\xff!Ô°\x10¤\x08ÆÑY
Recv: \x7f\x08Ä\xff°\x00F\xff%\xff\x000±F\xff¡\x00ð\x86V\x08\x04\xff\x000±F\xff1ú\x000±\x10F\xff1ú\x100±\x10\x08¡\x000±¾R\x08!ÕÀ0±\x00F\xff%\xff\x000±\x80F\xff\x86\xff\x000±\x96\x08\x84\xff\x000±\x10F\xffñÔ\x000±\x10¤\x08ÆÑ\x08w\x08Æ\xff\x08\x7f\x08\x96\xff\x12¡õ¯á%õ»¤\x08\x94Ñ\x10F\xff±\x10\x08¡õ\x10\x081\xff0\x12\x86VF\xff¡0\x12\x86V\x08\x84\xff0\x12\x86VF\xff1úð\x000±\x10F\xff1ú0\x12\x86~\x10\x08¡0åF\xff!ú°\xffF\xff!õ°\x80F\xff\x86\xff°F\xff\x84\xff°\x02F\xff!Õ°\x10F\xff!Ô°\x10¤\x08ÆÑ0
Logs for 230400 baudrate
Connected to: Serial<id=0x6a9d88f0, open=True>(port='/dev/ttyUSB0', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Recv: \x8b¶©\x14\x99Z\x8aå\x05Ñ\x1e\x8bÀÀ|±<Í`
\x92àÂþ\x9a°\x19ç\xff\x98\xffÙÏÆÄ\x93\x99¦Mý[TÏ\xff[r\x12$³\xff\бù\x93Eâvö\x14\x8aþ]³\x8dÙ\xff\x95Ì\x06\xff0\x84&\x93ë\xff\x14Ñ\x85&\x93â:\xff\x98\x84\x1aÓ5f\xff\x83¡Ó³\x8dF\xff\x92ó>÷Ì]°b¤þ½\xffØ\x99\x8aþFø\x98È\x8bþ&\x91\x8aþP\xff;\â
ÁRë\x8d\x06\xff5ÛeÌÙÝ5¬\x03ó$\xff\x18ESãd\xffLæ¶\x8aþ]\x14\x9a\x99\x18$\xffÌ\x98pÓ\x8dOø\x85Ó\x93\x8b\xffÍø\x85\x9a\x93â¥\xffÌæ¶¦ãÍöÌ8¶\x0c\x8dt\xffL\x9aÓææ\x90Å\x85\x9a\x996_þ ù\x85Ó\x93\x8bþ\x06\xff\x98\x1aö\x8b5\x12ô<fæ\x92\xffíBãÑ\xff²\x8b\xff\\x89´\xff>E|{ÍÜ\x8a\xff\x06\x9cÌ\x0fðÜ\x9d\xff
ðÑ\x9d\x9a\x93\x8b\xff ùñ¡ÓÚ\x8d\x145Ìæ¶\x8a\xffOùÑ\x85Ó\x99\x98ÌFùÑ\x14\x9a\x93\x9d\xfføÍ\x87Ãâ]ùÃÕ\x8d\x0fù\x12{ÜÙ\xff\x91\x8aþÒ\xff\x18\x8e\x8aþ
Á0Ú```
Logs for `115200` and below:
```Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0x6aa110b0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125```
You may install this:
Malyan/Monoprice Connection Fix
That is a typical response when the baudrate is not correct. OctoPrint should keep trying other rates until it 1) finds one it likes or 2) runs out of baudrates to try. My guess is that one of the baudrates selected may be the right one but the printer response is not what OctoPrint expects.
Edit: What @Ewald_Ikemann said!
Unfortunately, the Monoprice plugin doesn't appear to resolve the issue.
Will continue my search & reply when I've found a solution. Thanks to all who've provided pointers thus far.
Using Malyan/Monoprice Connection Fix Plugin to create serial connection
Connected to: Serial<id=0x6f616e10, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 9600
Recv: {ùý\xffû>lþ\xff¿\xffþþ_þ÷\xff\xff\xff\x7fþ\x9bßo\xff÷6<þüû
Recv: ¿
Recv: \x9f¿
Baudrate test retry #1
Baudrate test retry #2
Baudrate test retry #3
Baudrate test retry #4
Trying baudrate: 115200
Trying baudrate: 250000
Recv: \x9011ú@\x01\x91\x91?
Trying baudrate: 230400
Recv: \x11\x05o
Recv: ä\x00\x1b\xff
Trying baudrate: 57600
Trying baudrate: 38400
Recv: é\x91
Trying baudrate: 19200
Recv: þþ
Changing monitoring state from "Detecting baudrate" to "Error: No more baudrates to test, and no suitable baudrate found."
Changing monitoring state from "Error: No more baudrates to test, and no suitable baudrate found." to "Offline (Error: No more baudrates to test, and no suitable baudrate found.)"
Connection closed, closing down monitor```
Inquired with Monoprice team in the Questions section at:
https://www.monoprice.com/product?p_id=40108
Hello, I had the same problem. I found out by looking at the included WiiBuilder configuration for the Monoprice Cadet that the serial port communicates at 1000000 baud. Yes, that is 1 million baud. you can confirm by connecting to the serial port with a terminal, but the short fix is to modify your local octoprint to show 1 million baud. You would need to modify the octoprint/util/comm.py file to include 1000000 in the list of potential baud rates.
Nice! I'll try that today! Thank you @worklife_balance!
No, you would not. Adding additional baudrates is what Settings > Serial > Additional Baudrates is for.
Worked great. Thanks, @worklife_balance & @foosel!
