Need help logging into raspberry pi
i have been using a raspberry pi for my octoprint for a while and it works perfectly. I needed to ssh a python file to collect position data from the printer and I dont know my username or password for that. When i tried to log into the raspberry pi it asked for a octopi login (dont know that either). I can login to the web just fine (tried that username and password and it doesnt work either.
Tried adding a password.txt file to the sd card but no luck. I also tried to load the command line but no luck either
N/A
no
n/a
Gee, if only you had added the requested Systeminfo.... We could see who the user running OctoPrint is and told you your user name. That could have triggered a memory for your password.
All I suggest now is to make a full backup, re-burn the SD, write down the username and password and then in the startup wizard, restore your backup.
My bad! This pi is from my company so someone else set up octoprint
octoprint-systeminfo-20241010125856.zip (39.8 KB)
User is pi - password is probably raspberry.
Using ssh, the password query will not echo so just make sure the caps lock is off and type the correct word...
