12MP IMX708 Autofocus Camera Module 3 with HDR Mode and PDAF
Camera is not working
Making sure it is properly connected and editing boot files
Yes
octoprint-systeminfo-20240304171556.zip (151.9 KB)
rev=$(awk '/^Revision/ { print $3 }' /proc/cpuinfo) && curl -L perturb.org/rpi?rev=$rev
Revision: b03115
Model : 4 Model B
Memory : 2 GB
Overvolt: No
Released: Q1 2022
Notes : (Mfg by Sony)
uname -a
Linux octopi 6.1.21-v7l+ #1642 SMP Mon Apr 3 17:22:30 BST 2023 armv7l GNU/Linux
/boot/config.txt
arm_64bit=0
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
dtoverlay=imx708
max_framebuffers=2
disable_overscan=1
otg_mode=1
arm_boost=1
start_x=1
gpu_mem=128
dtoverlay=imx708-b0311
/boot/octopi.txt
camera_usb_options="-r 1920x1080 -f 10"
camera_http_webroot="./www"
camera_http_options=""
enable_network_monitor=0
destination_host=192.168.1.1
libcamera-hello --list-cameras
No cameras available!
webcamd.log
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video10
<13>Mar 4 17:08:34 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 1920x1080 -f 30 -d /dev/video10
MJPG Streamer Version.: 2.0
i: Using V4L2 device.: /dev/video10
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 30
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Done bringing up all configured video devices
Scanning again in two minutes
