elp-usb8mp04af-v72 / ELP 8mp
I cant figure out how to view the stream from this USB camera
I have edited octopi.txt. it is MJPG compatible so I did not add the -y parameter. I also uncommented the camera options toward the bottom in accordance to this guide. Info can be found online for the full specs but I configured it for the max supported 3264X2448 MJPEG@15fps
The stream url is the default /webcam/?action=stream
lsusb output is
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 32e4:8430
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
(it's Device 006: ID 32e4:8430)
Yes
octoprint-systeminfo-20230904161611.zip (1.4 MB)
Octoprint 1.9.2, Ender 3 4.2.2, Raspberry Pi 4B 4gb, Windows 10 pc, octoscreen, octoeverywhere
