Hi@all
I got the same failure when updating to the latest versions.
network failure, please check logs, but I get a green box it would be all up to date
In the log file SSL failure is mentioned.....
I checked my time and set the DNS-Nameserver to8.8.4.4 208.67.222.222
no
no
2023-12-27 07:00:16,202 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2023-12-27 07:00:16,264 - octoprint.plugins.softwareupdate - ERROR - Could not fetch check overlay from https://plugins.octoprint.org/update_check_overlay.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /update_check_overlay.json (Caused by SSLError(SSLError(9, '[X509] PEM lib (_ssl.c:4262)')))
2023-12-27 07:00:18,936 - octoprint.server.util.flask - INFO - Passively logging in user Feuer-Fritz from ::ffff:192.168.178.27
2023-12-27 07:00:18,938 - octoprint.access.users - INFO - Logged in user: Feuer-Fritz
2023-12-27 07:00:20,525 - octoprint.server.util.sockjs - INFO - User Feuer-Fritz logged in on the socket from client ::ffff:192.168.178.27
2023-12-27 07:00:21,277 - octoprint.plugins.announcements - ERROR - Could not fetch channel important from Important OctoPrint Announcements
File "/home/pi/oprint/lib/python3.9/site-packages/urllib3/util/ssl.py", line 402, in ssl_wrap_socket
context.load_verify_locations(ca_certs, ca_cert_dir, ca_cert_data)
ssl.SSLError: [X509] PEM lib (_ssl.c:4262)
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/plugins/announcements/init.py", line 490, in _get_channel_data_from_network
r = requests.get(url, timeout=3.05)
File "/home/pi/oprint/lib/python3.9/site-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/home/pi/oprint/lib/python3.9/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/home/pi/oprint/lib/python3.9/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/lib/python3.9/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/lib/python3.9/site-packages/requests/adapters.py", line 517, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by SSLError(SSLError(9, '[X509] PEM lib (_ssl.c:4262)')))
2023-12-27 08:43:51,777 - octoprint.plugins.announcements - ERROR - Could not fetch channel plugins from OctoPrint Plugin Repository
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/plugins/pluginmanager/init.py", line 1991, in _fetch_repository_from_url
r = requests.get(repository_url, timeout=3.05)
requests.exceptions.SSLError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by SSLError(SSLError(9, '[X509] PEM lib (_ssl.c:4262)')))
2023-12-27 09:04:56,184 - octoprint.plugins.softwareupdate - WARNING - Could not check octoprint for updates due to a network error
2023-12-27 09:04:56,246 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2023-12-27 09:05:02,490 - octoprint.plugins.softwareupdate - WARNING - Could not check octoprint for updates due to a network error
2023-12-27 09:05:02,556 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
What is to do now?
