Updated to Octopi 1.0.0 and enabled network monitoring. I see in the networkcheck source code there are echo outputs. Are those logged somewhere so I can verify it's running and working, or is there another file I can watch that would output the echos?
Could you try journalctl -u networkcheck.service? I think that should show it.
That worked great, thanks! It's working and didn't need to reboot to turn it on when I enabled it mid-print.
