I loaded new 0.18.0 on my Pi 4B which was running previous version with no issues. I have multiple Pi's running 4 different machines. I have always loaded with the IP address once the program loads identifying the IP with a small screen the first time I load them. I have 4 separate web pages one for each printer. I have loaded the new 0.18.0 and now it does not show the IP address like the others do it just says it can be accessed here with a blank IP address. I obviously can't use the local method becsaue it finds the other printers.
Am I doing something wrong or how do i find this Pi's IP so I can access it via web.
I am using a mac mainly to access it via Safari.
Keith
I do that and it does not show me the ip address. its blank. I reloaded the software on the disc with the older version and the IP is back but with the newest version its not there
same way I did with the previous versions through the command shift x menu where I set Wifi and network name etc. I loaded another card only 64GB and it worked fine but on the 128 card will not show the ip address. Its not a problem I just went with smaller card for now, thanks
