Raspberry camera not working
Reboot Pi several times both with printer turned on and turned off.
Have run raspi-config and enabled camera.
Checked for camera enable in xwindows and it is enabled.
have already run apt get update and apt get upgrade before installing camera.
Checked for camera log in var/log/webcamd.log --> it does not exist
re-seated ribbon cable, seems good, I do get a red light on camera but it is not coming up in the Octoprint UI.
Here is the camera I have, is this the problem? https://www.amazon.com/gp/product/B084X8MZ9J/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
lsusb returns the following. I don't even know if one of these is my camera.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 413c:2107 Dell Computer Corp.
Bus 001 Device 003: ID 0461:4e22 Primax Electronics, Ltd
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Complete Logs
Checked for camera log in var/log/webcamd.log --> it does not exist, see below. What else should I add for log files? I don't think the octoprint logs would be helpful here since this isn't a printing issue. Here is the main OP log. octoprint.log (51.7 KB)
pi@octopi:~ cd /var
pi@octopi:/var cd log
pi@octopi:/var/log $ ls
alternatives.log fontconfig.log syslog.1
apt haproxy.log syslog.2.gz
auth.log haproxy.log.1 syslog.3.gz
auth.log.1 haproxy.log.2.gz syslog.4.gz
boot.log kern.log syslog.5.gz
bootstrap.log kern.log.1 user.log
btmp lastlog user.log.1
daemon.log lightdm wtmp
daemon.log.1 messages Xorg.0.log
debug messages.1 Xorg.0.log.old
debug.1 private Xorg.1.log
dpkg.log regenerate_ssh_host_keys.log Xorg.1.log.old
faillog syslog
Raspberry Pi 4
OctoPrint 1.4.0 running on OctoPi 0.17.0
New to Octoprint, thanks for the help.
