Logitech C930e
Generic Endoscope camera
I started from a fresh install of octopi with the new camera stack and restored from a backup of my previous Octopi instance. I then followed the instructions for adding two cameras (first on 8080, second on 8081 with the listen option) and it worked fine... until I rebooted. Upon reboot, I could only get the Logitech camera to work. Tried changing the resolution and format for both cameras, no luck. Then tried restarting the pi with only the other webcam installed and was able to see the other camera. Plugging in the logitech again, I was able to see both cameras. Rebooted a second time with both plugged in, now only the endoscope camera server loads and the logitech stream does not.
See above
Yes (manually access stream via URL shows same problem)
Noe
octoprint-systeminfo-20240314215919.zip (120.5 KB)
Octopi on Raspberry Pi 4B, not plugged into 3d printer
