C270
No matter what I do (edit usb-default.conf, update system, restart services) there is no image and "server error" message is displayed
Clean install of the newst image, updating whole system AND relevant packages to newst available versions, editing .conf files.
Camera is properly detected by the OS, settings are all ok, but there is no image.
my usb-default.conf looks like that:
Options for USB based cameras
The port on which the webcam server for the camera should listen on. If you have only
one camera, leave at 8080. If you have more, change to 8081, 8082, etc. The primary
camera will be considered the one with 8080.
PORT=8080
The path to the camera device. Leave as is if you are using no or only one USB camera.
DEVICE=/dev/v4l/by-id/usb-*-video-index0
The image format of the camera.
FORMAT=MJPEG (also tried JPEG and YVUV)
The resolution to set on the camera. Defaults to 1280x720.
WIDTH=1280
HEIGHT=720The framerate to set on the camera. Defaults to 15fps.
FRAMERATE=30 (also tried 10 and 15)
NBUFS=10 (tried 2 and disabled)
Additional options.
OPTIONS=--http-listen=0.0.0.0 (also tried without this line)
YES
NO
octoprint-systeminfo-20240827014222.zip (50.5 KB)
