I created a boot SD card, flashed the current octopi image using Etcher on MacOS. On the mac i edited the supplicant file. I added an empty file "ssh" to the boot folder.
I move the SD card to the brand new RPi 4B and it comes up and connects to Wifi. Ping works. ping octopi.local works. ssh pi@ or pi@octopi.local does not work. Any ssh attempt gets "Connection refused".
I move the SD card back to my Mac and the ssh file is gone from the boot folder.
I create the ssh file again. I eject the SD card and remove it. Then I put it back into the Mac. I verify that the ssh file is there. It is.
I tried creating the ssh file using touch as well as saving an empty text file, no difference.
Everything involved is up to date and/or new. I brought the RPi 4B up on Raspian first. Got ssh and VNC both working.
The message above was mostly due to an IP address mixup. However:
The startup instructions for octopi should include the need to put the empty ssh file in boot.
Then, on MacOS, ssh will not connect because "strict checking" is selected. I created a config file in .ssh that turns off strict checking for local hosts. The information came from here: macos - Disable StrictHostKeyChecking in ssh - Ask Different
After getting into SSH, I ran rasp-config. Enabling VNC did not work. Select Option 8, update raspi-config first. Then VNC can be enabled.
No, they shouldn't, because OctoPi ships with this file already included. And I'm absolutely certain about this because I routinely flash stable OctoPi version 0.15.0, 0.15.1, 0.16.0, 0.17.0 and 0.18.0 as part of the update tests.
If the file was missing on your flash, either you caught a broken (nightly?) image, something with your card was off or your file browser didn't show you this file for some reason. But stable OctoPi ships with SSH enabled 100%.
VNC is a desktop thing and the default OctoPi image(s) don't include/enable the desktop.
