I have created a backup due to the Python update and loaded and installed the new image via the Raspi Imager. When I access the Raspi, I can also select the backup. The “load” window appears, but then nothing happens. I have reloaded the image several times, even once from the website. It doesn't change the fact that it won't load.
Since I can access the OctoPi website and SSH also works, I assume that OptoPi and the Raspi are working.
If it's a large backup it can take quite some time to restore, depending on what device it's running on. Like Ewald said, how long did you wait? Another option is to copy the zip file into the backup data folder so it gets listed in the existing backup list and then restore it from there, or remove any timelapses in the backup that could be making the file super big.
