New installation of Octoprint. Can not connect. Get error messages on consol:
" Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)
There are also many connection messages: "Server Off line", "Please Reload New Version, Server Available Reload Now?" (Answered YES), " Attempt Reconnect" and sometimes they started over and re-cycled.
In OctoPrint Settings - Serial - the Internet Connectivity Test does not work. The Resolve Name does work.
Tried connecting with IP address and with Octopi.local and both connected.
Tried setting fixed 9600 Baud rate.
Changed cables. Changed Pi power supply. Put tape on positive USB contact.
Checked to see if I could log on to Pi OS with this network installation with Putty and I could.
Yes
No change. Except for message - Running in Safe Mode
(I don't think Pi was running anything at all).
Complete Logs
Here is at least a complete cycle In safe mode (these are the tails of the log after many attempts):
Serial.log:**
2021-02-18 01:28:10,248 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:28:10,673 - Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:28:10,690 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:28:10,769 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:33:03,669 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:33:03,895 - Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:33:03,900 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:33:03,934 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:46:26,570 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:46:26,958 - Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:46:26,963 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:46:26,994 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:48:16,008 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:48:16,273 - Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:48:16,278 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:48:16,331 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 02:01:42,396 - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 02:01:42,664 - Performing autodetection with 0 port/baudrate candidates:
2021-02-18 02:01:42,669 - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 02:01:42,707 - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
*************Formatted Octoprint.log:*************
2021-02-18 01:26:40,660 - octoprint.server - INFO - Shutting down...
2021-02-18 01:26:40,781 - octoprint.server.api.system - WARNING - Command for core:restart_safe failed with return code -15:
! STDOUT:
! STDERR:
2021-02-18 01:26:41,162 - octoprint.server - INFO - Calling on_shutdown on plugins
2021-02-18 01:26:41,170 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2021-02-18 01:26:41,229 - octoprint.events - INFO - Event loop shut down
2021-02-18 01:26:41,802 - octoprint.server - INFO - Goodbye!
2021-02-18 01:26:58,959 - octoprint.startup - INFO - ******************************************************************************
2021-02-18 01:26:58,976 - octoprint.startup - INFO - Starting OctoPrint 1.5.2
2021-02-18 01:26:58,980 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2021-02-18 01:26:58,982 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2021-02-18 01:26:58,984 - octoprint.startup - INFO - ******************************************************************************
2021-02-18 01:27:26,932 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: offline
2021-02-18 01:27:26,935 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:50 is not working
2021-02-18 01:27:26,937 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
2021-02-18 01:27:26,974 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2021-02-18 01:27:27,309 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2021-02-18 01:27:37,030 - octoprint.plugin.core - INFO - Found 17 plugin(s) providing 17 mixin implementations, 34 hook handlers
2021-02-18 01:27:38,948 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2021-02-18 01:27:39,017 - octoprint.server - INFO - Intermediary server started
2021-02-18 01:27:39,291 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2021-02-18 01:27:43,127 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2021-02-18 01:27:43,159 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2021-02-18 01:27:43,163 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2021-02-18 01:27:43,180 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2021-02-18 01:27:43,186 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2021-02-18 01:27:43,198 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
2021-02-18 01:27:43,213 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2021-02-18 01:27:43,225 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2021-02-18 01:27:43,230 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
2021-02-18 01:27:43,245 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2021-02-18 01:27:43,259 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2021-02-18 01:27:43,273 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2021-02-18 01:27:43,277 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_install'), Need(method='role', value='plugin_pluginmanager_manage')")
2021-02-18 01:27:43,293 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2021-02-18 01:27:43,304 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2021-02-18 01:27:43,315 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
2021-02-18 01:27:52,166 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-02-18 01:27:59,628 - octoprint.util.pip - INFO - Version of pip is 20.3.3
2021-02-18 01:27:59,644 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-02-18 01:27:59,649 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-02-18 01:28:00,534 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2021-02-18 01:28:00,876 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2021-02-18 01:28:01,178 - octoprint.plugin.core - INFO - 17 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| File Check (2020.8.7) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| Pi Support Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2021-02-18 01:28:01,388 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 386326528
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi Model B Rev 2
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2021-02-18 01:28:01,508 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2021-02-18 01:28:01,642 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2021-02-18 01:28:08,724 - octoprint.server - INFO - Shutting down intermediary server...
2021-02-18 01:28:09,120 - octoprint.server - INFO - Intermediary server shut down
2021-02-18 01:28:09,138 - octoprint.events - INFO - Processing startup event, this is our first event
2021-02-18 01:28:09,141 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2021-02-18 01:28:09,165 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2021-02-18 01:28:09,167 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2021-02-18 01:28:09,211 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2021-02-18 01:28:09,565 - octoprint.server - INFO - Trying to connect to configured serial port None
2021-02-18 01:28:10,281 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:28:10,308 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2021-02-18 01:28:10,338 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2021-02-18 01:28:10,687 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:28:10,692 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:28:10,770 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:28:10,869 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-18 01:28:11,476 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2021-02-18 01:28:12,376 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2021-02-18 01:28:12,410 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2021-02-18 01:28:12,558 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2021-02-18 01:28:12,562 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2021-02-18 01:28:14,351 - octoprint.plugins.announcements - INFO - Looks like we are offline, can't fetch announcements for channel _important from network
2021-02-18 01:28:14,516 - octoprint.plugins.announcements - INFO - Looks like we are offline, can't fetch announcements for channel _releases from network
2021-02-18 01:28:14,521 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2021-02-18 01:28:14,654 - octoprint.plugins.announcements - INFO - Looks like we are offline, can't fetch announcements for channel _blog from network
2021-02-18 01:28:14,709 - octoprint.plugins.announcements - INFO - Looks like we are offline, can't fetch announcements for channel _plugins from network
2021-02-18 01:28:14,753 - octoprint.plugins.announcements - INFO - Looks like we are offline, can't fetch announcements for channel _octopi from network
2021-02-18 01:28:30,338 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2021-02-18 01:28:30,369 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2021-02-18 01:28:30,372 - octoprint.util.pip - INFO - ==> pip ok -> yes
2021-02-18 01:28:30,476 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 25.4GB. That is considered sufficient for updating.
2021-02-18 01:28:30,479 - octoprint.plugins.softwareupdate - INFO - Not fetching check overlays, we are offline
2021-02-18 01:28:34,986 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:28:36,536 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:28:36,579 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:28:42,850 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2021-02-18 01:28:46,159 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.1.67/', 'path': '/', 'query_string': 'l10n=en'}
2021-02-18 01:28:48,060 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2021-02-18 01:29:04,634 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:29:06,005 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:29:06,029 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:29:06,496 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:29:06,649 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:29:07,775 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:29:26,788 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:29:34,018 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:29:34,043 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:31:17,409 - octoprint.server.preemptive_cache - INFO - ... done in 151.25s
2021-02-18 01:31:17,412 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://octopi.local/', 'path': '/', 'query_string': 'l10n=en'}
2021-02-18 01:31:25,642 - octoprint.server.preemptive_cache - INFO - ... done in 8.23s
2021-02-18 01:31:28,020 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:31:28,024 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:31:33,366 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:31:33,501 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:31:33,505 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:31:41,161 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2021-02-18 01:31:43,304 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:33:03,671 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:33:03,897 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:33:03,914 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:33:03,951 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:33:04,051 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-18 01:35:42,998 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:35:43,292 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:35:43,424 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:35:43,427 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:35:43,619 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:42:38,969 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-18 01:43:52,674 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:43:52,968 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:43:53,161 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:43:53,165 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:43:53,304 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:45:18,653 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:45:18,917 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:45:19,044 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:45:19,048 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:45:19,181 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:45:49,374 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:45:49,574 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:45:49,701 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:45:49,705 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:45:49,990 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:46:26,577 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:46:26,960 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:46:26,964 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:46:27,010 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:46:27,104 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-18 01:48:16,011 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 01:48:16,274 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-02-18 01:48:16,303 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 01:48:16,342 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 01:48:16,455 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-18 01:48:38,404 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:48:39,938 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:48:40,191 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:48:40,194 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:48:40,465 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:49:02,114 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:49:05,194 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:49:05,199 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:49:16,847 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:49:16,851 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:49:22,838 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:49:23,138 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:49:23,153 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:49:28,423 - octoprint.plugins.pluginmanager - INFO - Looks like we are offline, can't fetch notices from network
2021-02-18 01:49:30,574 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:49:56,530 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 01:49:57,060 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 01:49:57,439 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 01:49:57,479 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 01:49:57,821 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 01:57:38,984 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-02-18 02:01:42,398 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-02-18 02:01:42,666 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 0 port/baudrate candidates:
2021-02-18 02:01:42,670 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
2021-02-18 02:01:42,721 - octoprint.util.comm - INFO - Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
2021-02-18 02:01:42,850 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-02-18 02:03:44,998 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 02:03:45,188 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 02:03:45,319 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 02:03:45,323 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 02:03:45,459 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 02:04:10,260 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 02:04:10,463 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 02:04:10,654 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 02:04:10,658 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 02:04:10,794 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 02:04:30,431 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 02:04:30,698 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 02:04:30,829 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 02:04:30,832 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 02:04:30,966 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 02:05:23,760 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
2021-02-18 02:05:24,018 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.227
2021-02-18 02:05:24,281 - octoprint.server.util.flask - INFO - Passively logging in user ghb from ::ffff:192.168.1.227
2021-02-18 02:05:24,289 - octoprint.access.users - INFO - Logged in user: ghb
2021-02-18 02:05:24,549 - octoprint.server.util.sockjs - INFO - User ghb logged in on the socket from client ::ffff:192.168.1.227
2021-02-18 02:12:29,103 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.227
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; rv:85.0) Gecko/20100101 Firefox/85.0
connectivity.connection_check: 8.8.8.8:50
connectivity.connection_ok: false
connectivity.enabled: true
connectivity.online: false
connectivity.resolution_ok: false
env.hardware.cores: 1
env.hardware.freq: 700
env.hardware.ram: 386326528
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi Model B Rev 2
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.5.2
Creality Ender-3 Pro w Marlin 0.0.6 firmware,
No camera.
Putty, Advanced IP Scanner.
Thank You.
