New stack and Raspberry cam module v3
Raspberry Pi camera module 3
Camera not seen in Octoprint. libcamera-hello --list-cameras sees it. libcamera-hello by itself reports
[1:02:11.883386376] [2813] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[1:02:11.906747783] [2814] ERROR V4L2 v4l2_device.cpp:353 'imx708_wide': Unable to set controls: Device or resource busy
[1:02:11.919174809] [2814] INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media1 and ISP device /dev/media0
[1:02:11.919237589] [2814] INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[1:02:11.919651679] [2813] INFO Camera camera.cpp:840 Pipeline handler in use by another process
ERROR: *** failed to acquire camera /base/soc/i2c0mux/i2c@1/imx708@1a ***
Multiple reinstalls. Kept trying the old and new stack to get arducam af to work reliably (no joy). Note: on the first fresh install of the new stack, the camera worked, and well. After manually installing octodash (restore doesn't do it), the octoprint no longer saw it. Cannot say whether this is causation or coincidince - but on my reinstall this morning, before installing octodash, octoprint did not see the camera.
No.
n/a
octoprint-systeminfo-20250130111540.zip (56.9 KB)
OctoPrint 1.10.3
OctoPi* 1.0.0cam (build 2024.11.05.100055)
Ender 3
Marlin bugfix-2.1.x
Safari and Firefox
MacOS Sequoia 15.2
Update, and blushes.
Hadn't fired up Octopod since the latest rebuild. Finally did so, and... the camera is there on Octopod. Not on Octopi...
Well, darn, and a whole bunch of juicer words.
The webcam plug was disabled.
Please ignore me. I'm leaving.
Stay. Mistakes happen :slight_smile:
I know... :slight_smile: The joys of not taking notes...
I noticed you are a mac user as well.
I am having the same issue with not being able to detect the cam BUT i do not really know how to work on the Terminal to do checks etc. Can i trouble you to give some brief guidance?
I also have OctoPod - but the camera just isn't detecting.
Ignore this - i have learned to use the terminal
