Just started using octoprint last night and was up all night trying to figure it out but still cant fix the following
Problem #1 i think Print settings are being ignored. Octoprint seems to be printing how it wants not what i set in cura. Print speed is being ignored i have set it for slow first print then speed up for rest of layers but print speed is the same, also tried setting it to print slow for certain prints but still same speed.
Im assuming all other settings are being ignored but not sure also cant find the print speed setting to manualy slow down speed
Problem #2 I have it set in cura to do an auto bed level test prior to each print which is ignored even tried putting it in octo print start code same thing no auto bed level. Only place i can do bed level was using a plug in prior to hitting print. Not a major issue but the fact its ignoring the commands makes me wonder what else is being ignored
Also ignores printers z offset setting had to download a plug in to manualy set up in octoprint
Probem #3 no bed heating when sd card inserted.
Problem #4 cant log into octoprint if logged out. I have to erase and reprogram sd card every time i want to get back in.
Problem #5 lcd screen sits idle doesnt show printing screen just stays on idle/settings screen
Cant tweak printing from printer while its printing.
Multiple reinstalls of octoprint
N/a
Ender 5 pro silent board upgrade(current creality firmware direct from creality). Latest firmware microswiss direct drive/hot end upgrade. Installed plug ins bed level and themefy, z axis plug in
Thanks for any help
