New to Octoprint & 3D printing
WRITE HERE I bought a Raspberry PI 5 thinking it was better than the 4? Now I see it's unsupported. What happens if I try to use my PI 5 with Octoprint?
Easiest solution is to flash the Raspberry Pi OS Lite and then SSH to the pi and use octoprint_deploy.
"Cutting edge technology" is not just a saying. It is referencing a blade, and sometimes it can be painful.
Just don't let this deter you.
-JC
To add some extra detail if it helps - the Raspberry Pi 5 is not yet supported by OctoPi, the pre-made OS image that comes with everything installed, because the RPi 5 requires newer software.
OctoPrint itself works fine on any of the devices, but you have to use the latest RPi OS version and use octoprint_deploy to install OctoPrint yourself. It's guided/automatic so should not be problematic.
I used the Octoprint deploy and that seemed to work fine until I got to the webcam part. I still can not get my webcam working. Could someone please show me the commands to type and where to type then so I can get my webcam working? Do I plug the webcam into the Raspberry Pi or the printers USB port? As I mentioned I am very new to 3D printing and Octoprint.
Thanks, i can use all the help i can get. Elegoo told me they can not help with installing a webcam....
