New user Fresh card, Asking for login? Used the Raspberry Pi Imager and the stable OctoPi build. Screen comes up in terminal and says "Octopi login? Also, I can't get to the command line.
I have no idea.
Imaged 2 different cards and googled the issue. no help
I have no idea how to do that
Yeah. see above.
See above ^2
new card, new image, imaged today with Raspberri Pi imager, AFAIK, I donot have this info. is there a default?
The credentials for the console login are (if you didn't change them in the pi imager)
username pi / pw raspberry
But if you just want to use OctoPrint you don't need that.
You use OctoPrint with your web browser: Connect the pi to your network (either via ethernet or enter your wifi credentials in the pi image before you flash the image) and then open http://octopi.local or http://octopi in your PCs web browser.
His Raspberry Pi screen, like mine, before this latest update displayed the Octoprint screen right at the printer, as well as on my laptop. That's what he (and I) are asking. Why doesn't Octoprint show up on the Pi's screen?
That's not (and has never been) default behaviour. The OctoPi image has never shipped with a local GUI, that's something you've added on/installed yourself.
What???? I've had 2 Pi's for years now that have the controls for the printer on the pi screen. You can select and print any gcode that you downloaded from the laptop Octoprint screen plus adjust and move all parameters. I must be in an alternate universe.
It's an X application that's executed directly in the X Server without a window manager or browser, and operates as a frontend for OctoPrint. Some of the functionality of OctoScreen included:
In addition to OctoScreen, if you have the desktop (and a browser) installed on the RPi, you use that to connect to the OctoPrint web server on the RPi.
Nope. Using the deb file on the Octoscreen website with or without the lines of code above it results in nothing but a sign in screen for pi. I do find a /esc/octoscreen/config folder but nothing in it. It appears the latest version of Octopi no longer supports Octoscreen! What a bummer that is!
