originally problem was not accessing octoprint through the browser but i can ssh and ping the address and going through the forums lead me to not getting logs to pass along and further going through the forums left me with some type of log to post here and since i been away from forums for so long i can't remember how to drop code or anything else needed here
followed some links through the community and did make my way to access some type of logs. they are greek to me so i;m still up poo river without a piddle to paddle.
because it kept starting in safe mode is why i got into this mess. kept failing at startup and i would reboot via sudo but regaining browser is hit and miss with the tendency to miss being the greatest.
i think in the past that the spaghetti detective was causing a hang up so i never tried to figure why i was in safe mode so i just never really messed with anything other than sending models through for prints. then one day i log on and it isn't in safe mode so, yay. but, then, in passing days, it would hang up on later attempts to log on and then go to safe mode on its own. which is where i am now, unable to access in a browser, in safe mode or not.
pi@cr-10s:~ octoprint systeminfo
-bash: octoprint: command not found
pi@cr-10s:~ ~/oprint/bin/octoprint systeminfo
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 8228372480
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.version: 1.7.2
systeminfo.generator: cli
pi@cr-10s:~ $ ~/oprint/bin/octoprint systeminfo .
Writing systeminfo bundle to /home/pi/octoprint-systeminfo-20220108211638.zip...
Done!
octoprint version: 1.7.2 octopi version: 0.18.0
printer: cr10s
firmware marlin: 2.0.9.2 2021-9-3
browser: microsoft edge and ios safari
os: windows 10 and ipados 15.1
yeah, i know now.
