Not able to logon via putty . I get
Access denied
I am loging to octtopi.llocal without problems
What username did you use? pi? Did you change the password or is it still the default raspberry
HI
I tied both pi and raspberrypi users. with both the password i set on first use via the browser setup and default password nothing worked.
I assume you have an English keyboard?
yes i its hebrew english but i see the username in english so i know its not in hebrew mode when typing
password
I just watched the youtube install and I believe I forgot the "Control shitt x" on the first image to SD ... so I tried reformatting my sd card now the PI doesn't seem to boot at all. Red light turn on but the green "act" doesn't flicker?? Suggestions??
which pi is it?
