Octoprint UI doesn't show up. It's stuct at "Loading OctoPrint's UI, please wait..."
Can't fix it.
Logs (syslog, dmesg, ... no logs, no support )
octoprint.log https://pastebin.com/4NeEqTbV
Additional information about your network (Hardware you are trying to connect to , hardware you are trying to connect from , router, access point, used operating systems, ...)
Debian Buster. Octoprint 1.4.2
Nginx config file https://pastebin.com/GspsLDeq
Nginx works with letsencrypt and has a redirect from HTTP to HTTPS.
In firefox inspector doing GET /octoprint/
I see:
You don't seem to have JavaScript enabled
OctoPrint's UI requires JavaScript to work. Please enable JavaScript and reload.
Also having lots of simmilar JS errors in console:
Could not bind view model UiStateViewModel to target #page-container-main : parseBindingsString@https://ibox.netng.pl/octoprint/static/webassets/packed_libs.js?df208d52:3:6802
Could not bind view model AboutViewModel to target #footer_about : parseBindingsString@https://ibox.netng.pl/octoprint/static/webassets/packed_libs.js?df208d52:3:6802
