No Advanced Option in Settings / Serial Connection Menu
What is the problem? No Serial Connection, no advanced option in Settings / Serial Connection menu
What did you already try to solve it? Have not found this problem as a topic anywhere online
Logs (syslog, dmesg, ... no logs, no support) [ 639.273195] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 660.859786] usb 1-1.5: USB disconnect, device number 7
[ 664.227893] usb 1-1.5: new full-speed USB device number 8 using dwc_otg
[ 664.361610] usb 1-1.5: New USB device found, idVendor=0483, idProduct=5740, b cdDevice= 0.00
[ 664.361643] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 664.361664] usb 1-1.5: Product: MARLIN_STM32G0B1RE CDC in FS Mode
[ 664.361681] usb 1-1.5: Manufacturer: STMicroelectronics
[ 664.361698] usb 1-1.5: SerialNumber: 205D314F574B
[ 664.363613] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 798.589791] usb 1-1.5: USB disconnect, device number 8
[ 800.678729] usb 1-1.5: new full-speed USB device number 9 using dwc_otg
[ 800.812361] usb 1-1.5: New USB device found, idVendor=0483, idProduct=5740, b cdDevice= 0.00
[ 800.812395] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 800.812415] usb 1-1.5: Product: MARLIN_STM32G0B1RE CDC in FS Mode
[ 800.812433] usb 1-1.5: Manufacturer: STMicroelectronics
[ 800.812449] usb 1-1.5: SerialNumber: 205D314F574B
[ 800.814343] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
[ 1027.711792] usb 1-1.5: USB disconnect, device number 9
Ender 3. Problem occurred after not using printer for approximately 1 year. Updated Raspberry Pi 3 to latest firmware. Pi is on the network via WiFi but have tested the problem with a LAN connection as well. No joy. Reconfigured all parameters as recommended. Can SHH into Rasberry, config and bring up GUI on a monitor. Replaced printer control board with a SKR Mini E3. No change. Still no serial connection. No Advanced option under Settings / Serial Connection. I'm not super tech savvy in this field but can follow instructions.
Any help would be appreciated. Thanks!
Dan3
Hello @Dan3 !
As your issue is about USB, I moved the thread.
Get Help - Networking is exclusively for LAN/WiFi/WLAN connection issues.
