Analysis is not performed of GCODE from Cura 3.2.1 (Direct from Cura and .gcode upload)
Tried direct print from Cura as well as slice to file and upload to octoprint webpage. Also tried starting octoprint in safemode. Ive tried gcode from Sli3r and it analyzes fine right away, its only gcode from Cura that's not analyzing.
Octoprint: 1.3.8
Octopi: .14
Printer: Monoprice Maker Select v2.1
Log:
2018-04-25 00:53:19,520 - octoprint.filemanager.analysis - DEBUG - Adding entry local:PI3_Eric.gcode to analysis queue with high priority
2018-04-25 00:53:19,521 - octoprint.events - DEBUG - Firing event: FileAdded (Payload: {'path': u'PI3_Eric.gcode', 'storage': 'local', 'name': u'PI3_Eric.gcode', 'type': ['machinecode', 'gcode']})
2018-04-25 00:53:19,530 - octoprint.events - DEBUG - Firing event: UpdatedFiles (Payload: {'type': 'printables'})
2018-04-25 00:53:19,551 - octoprint.events - DEBUG - Firing event: UpdatedFiles (Payload: {'type': 'gcode'})
2018-04-25 00:53:19,573 - octoprint.events - DEBUG - Firing event: Upload (Payload: {'path': u'PI3_Eric.gcode', 'name': u'PI3_Eric.gcode', 'file': u'PI3_Eric.gcode', 'target': u'local'})
Nothing in log related to the file after that and no details of the gcode appear in octoprint.
